| Quote:
This facility is available as a retro fit for the LS2 / LS3 engines, as the standard system has to be converted to give displacement on demand. This involves changing the lifters and modifying the ECU, which can also be suited to a fully electronic auto gearbox system.
__________________ Ian British American Engines / Daytonas www.britishamericanengines.co.uk / www.badaytona.com You Tube Channel: http://youtube.com/profile?user=BigThirsty1 Latest Build: Brian Cartmels 330 bhp turn key Chevy 350 C.I. for his Cobra replica http://uk.youtube.com/watch?v=AopjO3wu5rI |
| are there any none-GM solutions around? Actually I know the new Chrysler V10 sports car has something like this, but I suppose I mean something suitable for retrofitting to Rover or Ford engines. Again, just idle thoughts, but it really does sound like a lot of sense for journeys involving 'traffic', and in the UK, thats a constant bug-bear.
__________________ CAP 326Y finally road legal. Pilgrim Mk III RV8. |
| It would be interesting to understand what the transition is from 4 to 8, for example is it akin to turbo lag.
| When I first saw DoD shown by Chevrolet, a few years back now, they were not just suppressing the injectors, but also the valve actuation, as the pumping losses with the valves operating normally on a "dead" cylinder were huge.
| Quote:
The LS DoD system will do the following:- Shuts off the individual coil for the spark Shuts off the injector for the fuel Shuts off the lifters, to stop valves opening unnecessarily To achieve the last point, the valley plate is changed to a hydraulic manifold, which diverts the oil away from the lifters and back down to the engine.
| The transition between four to eight and back to four again is virtually undetectable and the MPG increase is around 15%. Should you want the ultimate in power delivery / fuel efficiency, we can supply both DoD and Variable Valve timing on certain LS engines.
| Quote:
So are the lifters hydraulically actuated, or is there a hydraulic" link" that can be interrupted to stop the valve opening?
| It uses hydraulic lifters as we understand them, but there is a hydraulic link which use solenoids to carry the oil away from the lifters.
| Another convert to "No replacement for displacement" | RickH | Newbies | 2 | 07-03-05 08:28 PM |
| Pedal displacement | callum | General Cobra Discussion | 4 | 28-08-01 09:33 AM |
