| Hi Denis, Just dug out my GD supplied flexible pipe set from the master cylinders through the bulkhead adapters in the wing and onto the bulkhead block mounted on the chassis and they are all -03 braided pipe and fittings. Not sure why GD would then use a -04 from the 3 way chassis mounting block to the clutch slave cylinder. I got my fittings and hose from Fay at Speedflow.
__________________ Best regards, Richard Dear GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!! |
| Quote:
| Thanks for the clarification David and to everyone else for their helpful comments. Much appreciated. Denis
__________________ If you take something to bits often enough, eventually you'll have two of them...... GD427E039 |
| Brake and Hydraulics advice. | martin_t | General Tech Tips & Questions | 6 | 12-01-08 11:06 PM |
| Clutch HELP! | TheUnixKid | Pilgrim Sumo Technical Questions | 7 | 21-08-05 11:14 PM |
| clutch | jamesandlouisa | AK Technical Questions | 2 | 17-03-05 07:43 AM |
| GD Hydraulics & SVA | ian744 | General Tech Tips & Questions | 4 | 01-02-04 10:39 PM |
| Excellent source for Hydraulics | wilf | General Cobra Discussion | 0 | 07-03-02 02:17 PM |
