| Hi Mark I planned to use the diff sensor in my car but the cables were unfortunately damaged whilst I was moving the diff about the garage. In the end I made up a plate with a large thread in it to hold a Smiths sensor in the same location as the original sensor. It worked fine and gave good readings but then I decided to change my diff to a lower ratio one. The new diff didn't have the pick up ring on the crown wheel so I then had to go over to the Tremec sensor which works equally well. No reason why the Jag sensor won't work though. I also thought of using one of the ABS sensors on the wheels. That should also work quite well. You might just be able to see it in the photo.
| Hi Mark, If you are using a Ford 302 what gearbox are you using? My suggestion would be to use the speedo drive from the gearbox, you should have a lot less bother in the long run.
| Do you know how many wires the Jag sensor has? I have the Jag wiring diagram at home so may be able to see what type of sensor it it. What type of gauges are you using? Craig.
| The car is having the exhausts done at the moment so i can't check, but i think there are two wires on the existing and both are damaged. I was going to replace it if it was a better, more accurate setup. The gauges are Dax supplied, Smiths Classic electronic speedo Mark.
__________________ Dax, Ford 302 I'm not a Gynaecologist But i'll have a look |
| Speedo Sensor - Where from? | AlexB | General Cobra Discussion | 3 | 30-06-08 12:37 PM |
| ETB Speedo Sensor | Marc | General Tech Tips & Questions | 4 | 03-01-07 06:20 AM |
| GD Speedo sensor | Glyn_Turner | General Tech Tips & Questions | 2 | 26-08-05 02:12 PM |
| ETB Speedo and SD1 sensor | chesterak | General Tech Tips & Questions | 15 | 06-05-05 04:55 PM |
| Speedo Sensor | greenster | Pilgrim Sumo Technical Questions | 7 | 06-07-04 01:10 AM |
