| 89 XJ40 3.6 Manual Jurid Diff Hi All, Just had a really quick look at my diff which is still in the rear sub-frame and found 2 info plates. One had '3.58' which is the ratio and the other had 'CBC7782' on it. Lloyd Barnes very kindly sent me the CD Parts Catalogue, but i cant find that part number in it. On page 33 it only lists JLM numbers which i cannot see. Also noticed a GKN stamp on the inspection plate. Any ideas to the spec of this diff? Cheers Fraz |
| interested to see if its a 'Normal' or a 'Power Lok' |
| Quite easy to test. Turn the input flange by hand and both the output flanges (or wheel hub if it's still in one piece) should turn in the same direction. If you then hold one of the output flanges and turn the input flange and you cant turn it, you have a powerlok diff. If you can still turn it, and the un-held output shaft still rotates then it's an open diff. Craig.
| diff if its a power loc diff it will have a tag plate bolted to it with PL stamped on it |
| No, its just a normal one for me then. Wasn't sure if they didn't lock till it had some power coming through them like an LSD. Cheers Fraz |
| 89 XJ40 Manual GBox, How Do i get it out??? | Gonch | General Tech Tips & Questions | 3 | 09-09-08 12:22 PM |
| 2.88:1 XJ40 diff | servistar | General Cobra Discussion | 7 | 15-12-06 03:48 PM |
| XJ40 PowerLok Diff or not | JamesP | DAX Technical Questions | 0 | 17-11-06 03:39 PM |
| XJ40 diff ratios again! | ajrnorth | DAX Technical Questions | 1 | 04-05-06 07:10 PM |
| XJ40 Maintenance Manual | bogster | General Tech Tips & Questions | 2 | 17-12-05 10:38 AM |
