Results 1 to 6 of 6
  1. #1
    Martyn-ak427 is offline Chief Engineer
    Join Date
    Mar 2005
    Location
    Nr Derby
    Age
    41
    Posts
    1,014
    Original Style Shifter
    Guys,
    Thought id post a couple of pics & a desciption of the original style shifter I have made for the AK. The shifter is a piece of 1/2" 316 stainless steel which I machined the groove & the rebate just below the original style gearknob. I threaded the end to take the gearknob 1/2" UNF & then drilled & tapped the centre of the of the shifter at the gear knob end to allow the reverse lockout to be held in place with a waisted bolt. I also drilled a hole & filed square to take the reverse lockout. Next step was to polish the shifter in a lathe using 600 wet & dry. Final step was to carfully bend the shifter in an industrial press. The lockout is made from a piece of 5mm 316 stainless which I cut out, filled & then finally polished with a buffing wheel to almost mirror finish. The whole job has probably taken me a day but I am really pleased with the end result & its saved me ~£80!
    Martyn
    AK with tyre-lighting 393ci Ford Stroker - 480hp & 475ft/lbs! - Sold!
  2. #2
    Neil O's Avatar
    Neil O is offline Driving God
    Join Date
    Feb 2003
    Location
    Honiton, Devon
    Age
    47
    Posts
    6,582
    Nice job Martyn, looks just like the one I bought from the States.
    You might get hacked off with catching your sleeve on the reverse lockout though.......don't ask how I would know.
    Crendon, Ford Cleveland
    Just went back 19 chassis numbers
    Chassis No.24
    New Crendon on order. Chassis No.66
  3. #3
    runt's Avatar
    runt is offline Chief Engineer
    Join Date
    Jan 2006
    Location
    Romford, Essex
    Posts
    1,692
    Thumbs up
    That is a thing of beauty Martyn, the talent of some of you chaps on here is amazing, really will be the final touch in the interior, and another thing to hold onto when you give that Windsor some wellie..
    Is the gearknob marked as a 4 or 5 speed..?
    Paul
    DB REPLICAS DAX no. 106
    'JOHN WOOLFE black'
    HUDDART FORD 351W, 393 ci
    Doesn't just accellerate.. bends time..
  4. #4
    TINKA is offline Driving God
    Join Date
    Apr 2004
    Location
    East Leake, Nottinghamshire, England.
    Age
    48
    Posts
    5,824
    Quote Originally Posted by Neil O View Post
    That is just you Neil never had any bother with mine
    Martin
  5. #5
    Join Date
    Mar 2005
    Location
    Nr Derby
    Age
    41
    Posts
    1,014
    Nice comment Paul - thanks.
    Gear knob is 5 speed.
    Regards,
    Martyn
  6. #6
    Clive's Avatar
    Clive is offline Technical Director
    Join Date
    May 2004
    Location
    Perth
    Posts
    4,177
    You'll need to remove the reverse lockout for SVA though.
    Cheers, Clive
    (If I'm not here, I'm either in my new workshop or on the golf course!)
  1. Auto Shifter
    By udxcob in forum General Cobra Discussion
    Last Post: 29-05-08, 03:20 PM
  2. Original-style quick-shift gear lever & gaitor
    By ian_uk1975 in forum DAX Technical Questions
    Last Post: 22-05-08, 11:49 PM
  3. Original style indicator stalk
    By ldtopham in forum General Tech Tips & Questions
    Last Post: 30-08-07, 04:26 PM
  4. Has anyone made their own toploader style shifter and/or qui
    By kayjayd in forum General Cobra Discussion
    Last Post: 07-03-06, 12:47 PM
  5. Anyone got an original 427 style gear shift in an AK?
    Last Post: 24-10-05, 09:22 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
