Results 1 to 8 of 8
  1. #1
    maddog's Avatar
    maddog is offline Spanner Holder
    Join Date
    Jan 2008
    Location
    Norwich
    Posts
    92
    Ford 302/347 engine block number
    I'm currently trying to prepare myself for SVA. In particlar, I'm trying to confirm the engine age, which I believe is based on the engine block only.
    The engine came from a company called Autocraft SVA. I have the original invoice with engine number and a stated year of 1991. The engine number on the invoice is OJ24-MF117882. Trying to anticipate the inspectors questions, I today removed the starter motor and tried to find the block number. I did find some numbers ie. OJ24 and some other letters which are puzzling me. I have taken a picture but as yet can not find the whole number as stated on the original invoice. I know the inspector is going to want clarification,but I can not find the second part of the number anywhere(MF117882).
    Is this engine a 1991 block as stated ????
    Is this going to cause me problems for SVA ???
    Can anyone help!!!!
    Mark
  2. #2
    maurice butler is offline Spanner Holder
    Join Date
    May 2008
    Location
    Temuka, NZ
    Posts
    92
    this will give you a clue how the date codes work
    FORD BLOCK CAR CODES
    oops try this one http://raceabilene.com/kelly/hotrod/engine.html
    Maurice
  3. #3
    maddog's Avatar
    Join Date
    Jan 2008
    Location
    Norwich
    Posts
    92
    Thanks Maurice!
    Still doesn't make any sence with my number
    Mark
  4. #4
    wilf is offline Banned for owning a STAG!!! Pit Babe Magnet
    Join Date
    Jan 2001
    Location
    On the naughty step
    Posts
    13,798
    I don't believe the pic you have is of the correct area, those are not casting codes.
    The code should be horizontal, viewable from the underside of the engine. Or from just below the block skirt line, anyway.
    Crendon has left the building................bright yellow Stag has landed.
  5. #5
    Koos.T is offline Spanner Holder
    Join Date
    Oct 2004
    Location
    South of Holland
    Posts
    78
    Hello Mark,
    Maybe this can help you
    Guide to Decoding Ford parts
    Dutch Road Runner
    Building
    GD427 MKIV
    Ford 5.0 EFI (Omex)
    http://gd-cobra.blogspot.com/
  6. #6
    andy l's Avatar
    andy l is offline Head Mechanic
    Join Date
    Nov 2005
    Location
    Plymouth. Devon
    Posts
    654
    Quote Originally Posted by maddog View Post
    Can anyone help!!!!
    Mark
    Hi Mark
    your engine block number is below the 34 in the pic,
    looks like F1SE which should be
    first position, decade F = 1990
    Second position year 1 = block 1991
    Third position car line S = Thunderbird
    Fourth position E = Engine
    Hope that helps, Andy
    DAX TOJEIRO DE DION
    CHEVY SB 383 STROKER 6.2Ltr 450 Hp
    Tremec TKO 3550 3.54.1 Jag Diff
    RCR Mk 1 GT 40 in build
  7. #7
    craggle is offline Pit Babe Magnet
    Join Date
    Oct 2003
    Location
    Southwater, West Sussex
    Age
    37
    Posts
    10,020
    Only Ford would have to point out to it's owners that it is actually the engine!
    Built a Dax once, Long time ago, painted it blue, original huh...?
    http://www.cobraclub.com/gallery/showgallery.php/ppuser/714/username/craggle
  8. #8
    maddog's Avatar
    Join Date
    Jan 2008
    Location
    Norwich
    Posts
    92
    Quote Originally Posted by andy l View Post
    Hi Mark
    Thanks Averyone!
    All that seems to make sense now.
    At least I have a very strong case for year of casting.
    I still can't find the second part of the number on the engine though ( OJ24-MF117882) other than a number on top of the block at the rear of the engine which is only part visible ( MF11............)????
    Will I need this for SVA or are they just interested in the Year?
    Mark
  1. Ford 302 engine number.
    By Andy302 in forum Engine Tech Tips & Questions
    Last Post: 10-05-08, 07:19 PM
  2. Casting Block Number
    By COBRA KEV01 in forum General Tech Tips & Questions
    Last Post: 06-04-08, 06:20 AM
  3. Ford big block FE who has done it
    By Pictus in forum DAX Technical Questions
    Last Post: 28-08-05, 04:58 PM
  4. Ford Windsor Engine Number
    By GlynnB in forum General Tech Tips & Questions
    Last Post: 10-09-02, 03:15 PM
  5. Big Block Engine Number
    By 460Jules in forum General Tech Tips & Questions
    Last Post: 10-04-02, 12:13 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
