+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: From Holes to Slots
  1. #1
    Geoff's Project's Avatar
    Geoff's Project is offline Club Supporter
    Join Date
    Feb 2008
    Location
    Atyrau, Kazakhstan & Angus, Scotland
    Posts
    714
    From Holes to Slots
    Is there a tool that I can use in an electric drill which will allow me to elongate a hole to a slot,
    Yes I have drilled some holes not quite in the correct location, slotting them is not a problem, I'm just looking for the right tool to do the job instead of using a file.
    Geoff
    Started - Building a 427 De-Dion, it has to be a Chevy 383
    Re-start the build
    This means nothing to me, ah Vienna!!!!!!!!!!!!!
  2. #2
    Clive's Avatar
    Clive is offline Senior Member
    Join Date
    May 2004
    Location
    Perth
    Posts
    4,006
    I used a 240 volt Dremmel. Dremel - Big on detail
    Cheers, Clive
    (If I'm not here, I'm either in my new workshop or on the golf course!)
  3. #3
    Gonch's Avatar
    Gonch is offline Club Supporter
    Join Date
    Sep 2008
    Location
    Hampshire
    Age
    32
    Posts
    690
    reamers allow you to drag holes as well. Or chain drill the hole and file in between.
    Building a Dax Tojeiro De-Dion, SBC
  4. #4
    Sidecarbod's Avatar
    Sidecarbod is offline Senior Member
    Join Date
    Mar 2006
    Location
    Location Location is a crap TV program
    Posts
    5,903
    Blog Entries
    1
    Tungsten carbide burrs spun with a dremel will cut through steel like hot butter cuts through a knife! The shavings that come off are like needles and are quite nasty!
  5. #5
    BLOKE's Avatar
    BLOKE is offline Club Supporter
    Join Date
    Feb 2003
    Location
    SHRIPNEY VILLAGE, SUSSEX, U.K..
    Posts
    738
    Red face Slotting
    if you use any of the methods above, clamp a piece of wood onto the job as a guide for the tool, otherwise it will wander and look a mess.
    Frank Dowsett. BLOKE.
    Quote Originally Posted by Sidecarbod View Post
  6. #6
    Join Date
    Feb 2008
    Location
    Posts
    714
    Tungsten carbide burrs look the business and Frank great idea about the peice of wood
    Cheers guys
    Geoff
    Re-start the build
  7. #7
    Steve's Avatar
    Steve is offline Senior Member
    Join Date
    May 2003
    Location
    Bridgnorth, Shropshire.
    Age
    48
    Posts
    2,753
    on fibreglass, a dremel fitted with a tile cutting bit works a treat
    Steve
    DAX 383 ci SBC 440hp...SOLD
    GD Euro mk4, 427 C.I. LS7, 540 hp...SOLD
    Project Tango "Old School" GD, ....SOLD
  8. #8
    chippy's Avatar
    chippy is offline Club Supporter
    Join Date
    Jan 2008
    Location
    Witney, Oxfordshire
    Posts
    112
    I have a dremel great bit of kit but burnt it out enlarging a hole in ss
    took it back to tool merchants and the dremel guys replaced it cant complain about that .then i purchased one of those wolf craft Felix drives that fits into a drill chuck .
    I find this has more power and more pen like to get into those tricky spaces
    Don't moan about your age just think yourself lucky you got there
  9. #9
    Hagster's Avatar
    Hagster is offline Club Supporter
    Join Date
    Jan 2005
    Location
    Weston-s-Mare
    Age
    42
    Posts
    892
    A handy tool is a Bosch multitool (all rounder) you can get a cheap corded one about £65 or a cordless. It has a flat spatular type blade you can just plunge straight into wood / fiberglass etc.
    Will plunge cut straight into a solid surface, imaging getting a wallpaper scraper and being able to just push it into a solid surface.
    Then you can drill two holes one at each end of the slot and plunge cut top and bottom to give you a perfectly straight slot.
    May not be the correct tool but its one of them tools that you will get out now and then and think wow thats just what I wanted.
    I use mine to sink in plug boxes / trim door bottoms / rip up flooring without damaging the planks all sorts of stuff.
    Regards Guy
    You can make a flush cut on top of a surface without marking the worktop that sort of thing, lots of adapters for it to do most things.
    small underpowered 302, not finished, messy engine bay, no bonnet rivets, seats are terrible, twin roll bars done and the wife's very happy.
  10. #10
    cobracol's Avatar
    cobracol is offline Club Supporter
    Join Date
    Jan 2009
    Location
    blackpool lancs.
    Age
    53
    Posts
    3,348
    There is a tool that you can fit to an electric drill and it nibbles at the steel so that you can produce any shape of hole or slot that you want! cannot find it but you see it at some of the shows
    AK 6.3 Chevy With (Gay) Power steering & Sidepipes (Cheers Wilf)
    Paintwork By www.surfaceanddesign.com
    My Gallery http://www.cobraclub.com/forum/membe...ol-albums.html
+ Reply to Thread
  1. Filling holes in GRP
    By purge98 in forum General Tech Tips & Questions
    Last Post: 08-03-07, 08:07 AM
  2. fuel dams and slots
    By Sidecarbod in forum Engine Tech Tips & Questions
    Last Post: 19-09-06, 08:06 AM
  3. What goes in these holes?
    By Andy302 in forum General Tech Tips & Questions
    Last Post: 07-07-06, 10:00 PM
  4. What goes in these holes?
    By JamesP in forum General Tech Tips & Questions
    Last Post: 21-04-04, 05:46 PM
  5. I have holes in my engine...
    By Dan in forum General Tech Tips & Questions
    Last Post: 22-04-02, 10:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
