Old 21-03-10, 08:40 AM
Suspension tweaks
Guys,
I havent really looked at the suspension setup on the AK since SVA & find it wallows a bit on uneven roads & when I corner hard I can get the tyre sidewalls contacted the inner wheel arches. To raise the ride height buy say 5-10mm do I turn the collets on the shocks clockwise compressing the springs? To stop the wallow I presume I turn the rebound knob on the shocks a few clicks towards the "+" sign?
Regards,
Martyn
AK with tyre-lighting 393ci Ford Stroker - 480hp & 475ft/lbs! - (Build Complete - Paint job March 2010!)
Old 21-03-10, 10:09 AM
Fuel Conservationist.
To raise the ride height you do need to compress the springs, Turn the collars clockwise to do them up. If you want 10mm higher though you won't need to turn them 10mm further up as the damper is halfway down the wishbone. Try maybe one turn of the collars and see what happens.
Turn the damper adjustment towards the + sign to make them stiffer. This should reduce the amount of bounce. I turned my ones fully anticlockwise then turned them fully clockwise counting the number of clicks.
I started in the middle of that range and adjusted from there.
DB Hardtop now being prepared for fitting.
Polishes to date = 29
BB code is On
Ignition tweaks - worth it?? ceejayjay General Tech Tips & Questions 3 01-03-07 08:25 PM
Suspension set up Clarkson General Cobra Discussion 7 01-04-06 08:04 PM
Suspension set up James General Cobra Discussion 5 18-07-04 09:35 AM
How to set up suspension? ldtopham General Tech Tips & Questions 2 16-02-04 07:29 PM
Jag Suspension AGAIN robert The Cockpit 9 23-07-02 09:30 PM
