Results 1 to 8 of 8
  1. #1
    Daren1974 is offline Tyre Kicker
    Join Date
    Jul 2010
    Location
    Hertfordshire
    Posts
    25
    Engine code for 351 Cleveland??
    Hi guys I would appreciate some advice on how to obtain manufacture date on a 351 Cleveland, it is a 4V closed chamber, 4 bolt main. Engine code on block is D2AE-CA , 2G18.
    Daren
  2. #2
    ldtopham's Avatar
    ldtopham is offline Chief Engineer
    Join Date
    Feb 2007
    Location
    West Yorkshire, England.
    Posts
    1,746
    That's a casting code. D2 = 1972. The rest I cannot desipher without my book. The actual assembly date will be stamped on the block end face directly behind the timing cover/ water pump plate.
    How to rebuild Ford V8's by Tom Monroe is a good book that expalins how to read casting dates etc as well as full rebuild info.
    HTH
    If it's in good nick then the block along with the CC 4v heads is a very good base to start a high performance motor
    Lee
    Understeer is hitting the wall with the front of your car, oversteer is hitting the wall with the rear.
  3. #3
    StewbieC's Avatar
    StewbieC is offline Head Mechanic
    Join Date
    Dec 2008
    Location
    Shropshire
    Posts
    959
    Hi Daren,
    D = Decade = 1970's
    2 = Year = 72
    A = Full size Ford (Depicts the car type)
    E = Engine Engineering
    Not sure about CA
    2 = again year 72
    G = Month = July
    18 = 18th
    Hope that helps.
    Got a mail from Ford technical to explain my 289 casting code, hope to use this for proof of block manufacture when I take mine for IVA.
    Stu
    _________________________________________
    Hawk 289 Powered by a FORD 289
    My Gallery http://www.cobraclub.com/gallery/sho...wk-289/cat/500
  4. #4
    Lloyd Barnes's Avatar
    Lloyd Barnes is offline Technical Director
    Join Date
    Nov 2006
    Location
    Shropshire/Wales Border
    Age
    43
    Posts
    4,597
    Quote Originally Posted by Daren1974 View Post
    Daren
    Hi Daren
    D = decade of manufacture, D = 1970's
    2 = year in decade... 2 makes it 1972
    A = Ford car line
    E = engine group
    Your 2G18 is a date code;
    2G18 means it was cast on 18th July 1972 (A being January, B Feb and so on)
    HTH
    Lloyd B
    Current: Crendon #54 in build - 427 Side Oiler/Cobrajet Heads/Dual 600cfm Holleys/4 speed toploader
  5. #5
    Join Date
    Nov 2006
    Location
    Age
    43
    Posts
    4,597
    hey stu. you clearly type faster than me!!
    Lloyd B
  6. #6
    StewbieC's Avatar
    Join Date
    Dec 2008
    Location
    Shropshire
    Posts
    959
    Quote Originally Posted by Lloyd Barnes View Post
    Yeah my two finger typing must be quicker
    Have you got that FE sorted and the Crendon ordered?
    Stu
  7. #7
    Join Date
    Jul 2010
    Location
    Hertfordshire
    Posts
    25
    Much appreciated guys, the engine bottom end is in very good Nick, the car has sat under. A tarp outside for about 5 years and has gotten some moisure up the exhaust into the ports and corroded a little. Will need an overhaul on heads, valve seats etc. Do you guys know a good reconditioners in the hertfordshire area? I also have a C6 trans shift kitted 2500 stall that needs doing also.
    Apologies if this is asking too much.
    Thanks again
    Daren
  8. #8
    Join Date
    Nov 2006
    Location
    Age
    43
    Posts
    4,597
    Thanks again
    Daren
    Worth a run down to Realsteel in Cowley Middlesex? They know what they are doing with yank blocks.
    Real Steel
    Lloyd B
  1. Mac code
    By kobra in forum The Cockpit
    Last Post: 15-07-09, 04:52 PM
  2. Ford Cleveland Engine mounts
    By craggle in forum Engine Tech Tips & Questions
    Last Post: 23-06-08, 08:35 PM
  3. cleveland engine number
    By pete175 in forum General Cobra Discussion
    Last Post: 28-02-08, 07:47 PM
  4. Cleveland engine
    By hairysanta in forum Engine Tech Tips & Questions
    Last Post: 19-12-07, 02:36 PM
  5. New Highway Code
    By Louise in forum The Cockpit
    Last Post: 02-02-05, 09:16 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
