Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Paul Kemp is offline Tyre Kicker
    Join Date
    Jan 2008
    Location
    South west Wales
    Posts
    26
    Fitting an Autometer mechanical oil temperature gauge to a small block Chevy 350
    Problem - 2 really. secret is out and Paul is fitting ( or trying to) the oil temp gauge, but there is nowhere to put the probe - only suggestion is in the sump but that seems potentially a vulnerable spot!
    Sandwich plates don't seem to have 1/2 inch or 3/8 inch npt outlets so that doesn't seem to be a possibilty.
    Autometer said they don't do much for small block Chevy - very prompt response ( good) but answer not helpful.
    Mocal don't seem to have any ideas - currently musing and may get back to us. But same response from other potential suppliers.
    Wanted all Autometer full sweep so they are all the same on the dash!!!! ( and it's what Ann bought me for Christmas!!)
    Any ideas, Chaps??!!
    Thanks, Paul Kemp ( and Ann Poole)
  2. #2
    bloke from stoke's Avatar
    bloke from stoke is offline Technical Director
    Join Date
    Sep 2009
    Location
    Stoke on Trent
    Posts
    2,677
    A little early for Santa
    Kind regards Lester
  3. #3
    cobracol's Avatar
    cobracol is offline Technical Director
    Join Date
    Jan 2009
    Location
    blackpool lancs.
    Age
    55
    Posts
    4,989
    Aye up Lester mate, Not too early, Sorry about the pic, couldnt resist!
  4. #4
    Clive's Avatar
    Clive is offline Technical Director
    Join Date
    May 2004
    Location
    Perth
    Posts
    4,301
    Sump is the best place for reading oil temp.
    Cheers, Clive
    (If I'm not here, I'm either in my new workshop or on the golf course!)
  5. #5
    StewbieC's Avatar
    StewbieC is online now Head Mechanic
    Join Date
    Dec 2008
    Location
    Shropshire
    Posts
    991
    Mine's a mechanical, full sweep Smiths and mine is connected to the sump.
    Stu
    _________________________________________
    Hawk 289 Powered by a FORD 289
    My Gallery http://www.cobraclub.com/gallery/sho...wk-289/cat/500
  6. #6
    kdavies3's Avatar
    kdavies3 is offline Driving God
    Join Date
    May 2004
    Location
    Cowbridge, United Kingdom
    Age
    56
    Posts
    7,951
    Hi Paul and Ann,
    I'd drill and tap the sump plug, unless of course it's on the bottom of the sump, or if you fancy a bit more work drop the sump and add a new boss to take the temp sender.
    I may be able to help with it if don't have anyone local with the tech to drill tap etc.
    Kev Davies
    South Wales Area Rep. UKCC Membership Secretary
    DAX Mk4, 383 Chevy Stroker, Tremec. SOLD
    Contemporary CCX 3-4028, 445ci Big Block FORD FE,TKO 600, Old School IVA'd and truly AWESOME
  7. #7
    wilf is offline Banned for owning a STAG!!! Pit Babe Magnet
    Join Date
    Jan 2001
    Location
    On the naughty step
    Posts
    13,798
    If you have an oil cooler fitted, Mocal make a housing that will accept the temp probe that will fit inline in the hose run out to the cooler (which should be equivalent to sump temp).
    Is how mine is plumbed. Only issue is that I have an oil stat in the take-off plate, and so I get no oil temp rreading until the 'stat opens, which is fine as it tells me the engine is warm enough for the red line to be available.
    Crendon has left the building................bright yellow Stag has landed.
  8. #8
    Lloyd Barnes's Avatar
    Lloyd Barnes is offline Technical Director
    Join Date
    Nov 2006
    Location
    Shropshire/Wales Border
    Age
    43
    Posts
    4,719
    advice on installing oil sensor on Chevy 350
    might be worth having a look at this thread. I used this location for my oil pressure sender but guess it would work for an oil temp sender as well.
    my temp sender was in one of the mocal remote housings as well, with a seperate stat after the housing so it was constantly in flowing oil. worked fine although quite an expensive route and no good to you unless you have an oil cooler already fitted.
    Lloyd B
    Current: Crendon #54 in build - 427 Side Oiler/Cobrajet Heads/Dual 600cfm Holleys/4 speed toploader
  9. #9
    snakebite is offline Head Mechanic
    Join Date
    Dec 2003
    Location
    Exmouth, Devon
    Posts
    713
    In my original chebby there was an NPT hole blanked off just above the oil filter which enters the oilway. Although the reading will be higher relative to a sensor in the sump it worked a treat.
    Steve Richards
    Growing old is inevitable - Growing up is an option
  10. #10
    kdavies3's Avatar
    Join Date
    May 2004
    Location
    Age
    56
    Posts
    7,951
    I think I've got my oil pressure warning in that one and my oil pressure wet line in the one adjacent to the dizzy.
    Kev Davies
  1. Chevy 350 Small Block
    By gftr3 in forum General Tech Tips & Questions
    Last Post: 03-09-08, 11:06 PM
  2. small block chevy
    By eng622 in forum General Cobra Discussion
    Last Post: 03-05-07, 08:37 AM
  3. 400 Ci Small Block Chevy
    By NIGELGD in forum General Tech Tips & Questions
    Last Post: 13-12-04, 12:44 PM
  4. Chevy Small block
    By AKBandit in forum General Tech Tips & Questions
    Last Post: 24-05-04, 10:19 PM
  5. Mechanical Water Temperature Gauge
    By martin in forum General Tech Tips & Questions
    Last Post: 03-01-03, 08:48 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
