Old 18-10-01, 01:12 PM
Carb upgrade for Rover V8
Hi Guys,
Am new to this experience so be gentle with me!
Currently running a Sumo with a bog standard Rover 3.5 lump fitted with twin SUs which I am looking to upgrade. There seem to be two choices (Weber 500 (?) v Holley 390. Depending upon which distributors site I read, I get different recommendations.
I have three questions I would appreciate answers to:
1. Which is the better choice?
2. What sort of impact can I expect on performance?
3. Is it an easy job to do ones self (Cobra Cars say it is not a job they would recommend done by a layman).
Two Greens
Old 18-10-01, 01:30 PM
RE: Carb upgrade for Rover V8
Two Greens - (what, not satisfied with one??)
There will be lots of folk who like either the holley, or the weber. Me? Don't like Holleys, but that's just my opinion.
If you are a layman, and not likely to actually do the swap yourself( which will mean new intake manifold as well as carb), nor know how to tune it afterwards, my advice would be to find someone you are happy with to do the work for you, and who has a GOOD track record in tuning the make of carb they recommend, then go with their recommendation. At the end of the day, I am not sure why you want to move away from the original SU's on a standard Rover V8 - I would think they were sufficient until you had done other mods (cam, heads) to be giving you over 200HP. I am not convinced you will get noticeable extra performance just by a carb swap, unless the new intake manifold is a million miles better than the original, and you could lose out in terms of mpg. However, if you want to do it just for the looks alone, go for it.
HTH
Wilf
Old 18-10-01, 01:41 PM
I've fitted a Weber (Edelbrock) 500 to mine on an offenhauser jwr dual-port manifold (this is the lowest profile one - though I could have used the higher profile edelbrock performer one). Weber 500, according to RPI and also an american engine specialist who set it up for me, is much better (for a rover engine) than a Holley - Holley's are difficult to jet and very prone to flooding.
Impact on performance - especially throttle response is amazing - Chris at RPi tried to convince me when I bought it that it would make a great difference - I thought it was just his sales pitch, but it _really_ did!! Impact on fuel bill is also noticable. Apparently its better for economy generally than the SUs but the weber has a mechanical accelerator pump so if your prone to flooring it (who isn't!! ) then it really does quite literally pour the fuel in!!
Fitting it is pretty easy, though you need to spend a bit of time working out where your throttle & choke linkages are going to go and where to route the heater pipes (the bottom heater pipe no longer fits under the manifold) and the fuel inlet is now going to be on the driver side. Once you have this worked out it really is just a case of unbolt the old and on with the new and is dead easy. All common sense no specialist knowledge required. Not a plug for RPi but they were extremely helpful in the installation; Holly (the engine builder) answered all of my questions before I even asked them - Speak to Chris or Holly and they will let you know exactly what it involves.
Setting it up is again quite easy theoretically - I had the carb jetted by RPi before they sent it and they seem spot on- I did however need to take it to an engine specialist (conveniently over the road from where I work) to sort out the idle mixture as my CO meter wasn't really up to the job and I also wanted it set up for HCs - Much easier than the SUs I spent about 2 months and lots of needles trying to get them right and eventually ditched them!!
Hope that helps
Stuart
Old 18-10-01, 08:18 PM
imported_admin
Guest
Posts: n/a
when you replace the manifold look out for a pillar of alloy used for mounting the choke cable on the edelbrock performer it fouls the rh rocker cover and prevents it from sealing properly causing an irritating oil mist leak.
either grind a notch in the pedestal or the rocker cover as you like and this is one less ptoblem . I have a webber and edelbrock and am a happy bunny.
check your fuel pump is up to i recommend carter pump as it has preset pressure so no regulator is needed.
have fun and dont be frightened
Old 18-10-01, 09:10 PM
Hi,have you thought about putting dellorto carbs on?.I run a rover V8 with quad dellortos and it is very rapid but a bit thirsty.
Old 18-10-01, 09:13 PM
Sideoiler -good point, -a carb change alone will not result in much difference in output, although as has been mentioned, throttle response can improve over the standard SU's.
Twin Greens - the moral seems to be that a cam change at the same time would be a good idea!
I have the Edelbrock (Weber) carb on my engine (not a rover). I like the ease of tuning, and the fact that it holds tune well. Also so much easier to set float levels etc than a Holley. No nasty gaskets below the fuel level to leak. No nasty power valves to blow. Thats why I prefer the edelbrock to the holley. I notice you mentioned a "500" carb - if that is 500cfm, I would have thought that it's too much for a std Rover. Not sure if edlebrock make a smaller one, might mean you have to go for the 390 Holley after all?? Anyone know different??
Wilf
Old 19-10-01, 10:15 AM
STEVE G's Avatar
Two Greens
I inherited A Holley on my rover on a converted SU manifold,which I changed for an Edelbrock performer.I could not get it to run right even after a complete carb rebuild.I agree with Wilf, get someone who knows to set up whatever you buy.My car went to Cheng at Thunder Road for a front suspension rebuild and whilst there he tuned the carb and did the timing etc. It is now a totally different engine, Good response and not as thirsty.Personally when I change my engine(next years project hopefully) I will get a Weber for ease of maintainence and performance.Anything looks better than SU's tho.
Regards Steve G
Old 19-10-01, 12:25 PM
I bought a part built GD with Rover V8 and Twin SUs (not running). Part of the deal was a new Weber kit (500 carb, Edelbrock performer manifold, pancake filter) all still in the box.
I consider myself a layman (I can weild a spanner and follow instructions) and no expert by a long shot.
I followed the instructions to the letter, spoke with Chris at RPI who suggested a suitable pump & Regulator, fitted the lot with no problems whatsoever.
I started the engine for the first time without having to touch any of the settings!! Which I guess says a lot for its ease of installation.
It looks as if its running rich, but I'll leave it a while before I find an expert to tune it (unless I get brave!).
Oh and it looks good too:7
Jim
Old 07-11-02, 08:20 PM
The chart is taken from a ’94 fast car magazine ,the three carbs (weber , holley , quad su and twin su) were fitted to a standard rover v8,second hand and of unknown quantity, with a real steel Hurricane cam fitted at @ approx £110
Graph colour as follows:-
Holley - green
Twin su - yellow
Quad su - red
Weber - blue
The Twin su was making 140 bhp
Weber made 176 bhp
Holley made 165 bhp
Quad su made 162 bhp
They concluded that the weber wins being the most complete package for your money
The scores out of 50
Weber 47
Holley 39
Quad su 32
The figures speak for themselves and the weber was easier to set up apparently
Rover v8 fuel pressure - EFI to Carb RichDyne General Cobra Discussion 9 19-07-07 11:13 PM
Rover V8 Upgrade Advice jabooth Engine Tech Tips & Questions 31 30-07-06 06:19 PM
Upgrade robert General Cobra Discussion 2 03-10-05 10:54 AM
Rover V8 and Carb Info Olddogjon Engine Tech Tips & Questions 0 18-09-03 05:17 PM
Rover v8 EFi or Carb ? DrFelch General Tech Tips & Questions 21 07-11-02 08:27 PM
