Old 18-12-01, 04:42 AM
simon's Avatar
ford windsor install
I should be in a position to install my engine/box in my chassis quite soon. I will hopefully have access to a hoist with a balance bar adjusting type thingy (sorry, don't know what it's called) but where would be the best position on the engine to attach the chains to?
Should I make up a bracket to bolt between the heads?
Any advice/pics/bits I could borrow, gratefully received.
Thanks
Simon
Old 18-12-01, 07:31 PM
RE: ford windsor install
Hi there Simon I have a lifting beam with short chains and plates to bolt to the cylinder heads I made it to suit my Chevy but if you want to borrow it and modify it to suit your engine your welcome
give me a call
cheers
Paul
Old 18-12-01, 11:16 AM
I have factory holes drilled on the ends of my heads, and using these with the balancer bar & short chains makes the engine very stable & easy to angle & install single handed
steve
Steve
DAX 383 ci SBC 440hp...SOLD
GD Euro mk4, 427 C.I. LS7, 540 hp...SOLD
Project Tango "Old School" GD in progress
Old 18-12-01, 09:49 AM
robert's Avatar
Administrator
Simon
Best bet is to buy a lifting eye. you remove the carb, and bolt the plate to the manifold and then lift the block.
It makes things so much easier than loads of ropes.
Best Regards
Robert
Forum Admin
Ein Mann, der eine Furtmaschine benutzt, hat ein kleines willy und ein Gardner Douglas mit der Maschine auf der Bank wertIST vier Crendons
Best Regards
Robert
Bayeaux and Back all for Project Mobility - Dig Deep
Some people are just like slinkies, they don't really have a purpose but they still bring a smile to your face when you push them down the stairs.
Old 18-12-01, 09:43 AM
see my post on installing my rover engine into my AK - should be fairly similar - sorry!!
Old 19-12-01, 02:18 PM
Simon - have always used "fabric" lifting straps around either end of the engine, adjusted to give the right angle of dangle. Sometimes if you go this route you need to space them off the block/heads to give clearance for distributors and the like.
Some of the "balance bars" I have seen look a bit lightweight to me, especially the chains dangling from them. Beware.
If you are installing with 'box attached, then removing the shifter also helps.
HTH
WIlf
My opinion is worth exactly what you paid for it. By the way - I was Right!
BB code is On
Ford 302Ci Windsor Engine ibroker General Cobra Discussion 4 10-10-07 02:21 PM
Ford 351 Windsor Oil Sump Martyn-ak427 General Tech Tips & Questions 2 06-06-05 09:27 PM
Ford 351 Windsor Books martyn thompson General Cobra Discussion 4 08-06-03 02:18 PM
Ford Windsor bellhousings ian General Tech Tips & Questions 5 24-03-03 08:32 AM
Ford 351 Windsor - how much? BenBaron General Cobra Discussion 4 08-09-02 09:13 AM
