| How mount the clutch to a Rover V8 ? I'm fitting a new clutch to my Rover powered Dax. The workshopmanual says I need to use a seperate shaft to position the clutch to the flywheel. I do not have such a shaft. Does anyone know a different way to do this ? Regards, Arjen Vink |
| RE: How mount the clutch to a Rover V8 ? Vince, If you've got an AC Cobra I would hardly imagine that a seven quid on an alignment tool is going to be a problem, I smell something and it begins with an 'B'. :7 |
| RE: How mount the clutch to a Rover V8 ? Though if you spent 7 quid on every tool you would only need once it'll soon get pretty expensive. I have a 5K engine but buying an alignment tool just for this never really crossed my mind. On my first attempt I used a socket extension which did just fine (in fact it could have been made for the job!), on my second I got RPi to do it for me with a spare gearbox shaft they had. Incidently I was quite alarmed to find that the new self-centring release bearing is plastic!! Stuart |
| RE: How mount the clutch to a Rover V8 ? I've not got my kit yet. I will be collecting it early Feb. It's an AK not an AC... I wish. Trouble Is I don't know how to correct it my profile. I did do the tape thing and it worked. Didn't realise that the alignment tool was only 7 quid though. I have bought quite a bit of stuff recently that I may only use once. Engine Stand, Piston Ring Compressor, I'll have to ask in the other forums if anyone near to me in Leeds has a Brake Pipe Flairing tool... Regards Vince@gledhill.info:9 |
| RE: How mount the clutch to a Rover V8 ? Hi Arjen. I was doing the very same thing last night. Basicaly the clutch alignment tool is two circles of Steel. One goes inside the end of the crankshaft and then the clutch needs to be centralised in relation to this. I made a tool like the one pictured with a large Philips Screwdriver and insulating tape. Simply wrap tape around the screwdriver until it just fits into the end of the crank. (see picture below) Then do the same again so that the tape at "B" on the drawing just fits inside the clutch preasure plate. Fit the whole lot in place and then fit your cover plate. Worked OK for me. OK so I wasted about a half a roll of insulating tape but it's better than shelling out for a clutch alignment tool that you would use only once. Regards Vince@gledhill.info |
| Rover V8 Clutch alignment | CeeJay | General Tech Tips & Questions | 9 | 12-03-08 12:43 PM |
| HELP ! Rover Clutch arm probs. | philip600 | General Tech Tips & Questions | 15 | 07-09-07 09:52 PM |
| ROVER SD1 CLUTCH | davew | General Tech Tips & Questions | 10 | 23-02-04 08:15 AM |
| Cracked Rover Engine Mount | Two greens | General Tech Tips & Questions | 9 | 07-11-02 09:21 PM |
| Rover Clutch Problem | Dan | General Tech Tips & Questions | 16 | 06-02-02 11:10 PM |
