| Chevy crank dampner Hi all, How does it come off ? i have removed the bottom pulley so im looking in at what seems to be a fat washer and some thread inside. I have tried to 'encourage' it off but still its happy where it is Thanx Kelvin |
| RE: Chevy crank dampner Thanx Norm I have sourced one of these, hopefully it will do the trick. It was a big hammer and still it didnt shift. Was thinking of heating it but then thought of the downsides. When i started my build i would have done just that but now i think twice before doing anything Cheers again Kelvin |
| RE: Chevy crank dampner Hi guys Just an observation but the puller shown in the attached image bears a striking resemblence to a Mini/Metro flywheel puller, might be worth a try ? Pete |
| RE: Chevy crank dampner Hi there Real Steel sell the correct puller / Installation tool part number BY61740 £32.01 INSTALLATION TOOL part number BYHBP-1 £10.05 REMOVER cheers Paul |
| RE: Chevy crank dampner THe puller is indeed very similar to a mini puller. If you have one, all you need to do is file out the slots in it a little bit to accomodate the greater diameter of the threads in the Harmonic damper than the mini unit is designed for, and Bob's your uncle! By the way, if you have been hammering on the balancer and you hope/expect to use it again then I would inspect it very closely. The outer part of it is attached to the inner part by rubber only, and if you distort it I wouldn't like to be anywhere near it when you rev the engine to 6 grand! Same goes for installation. You can buy the expensive installation tool, or, like most of us, 'pursuade' it on with Special Tool No1. Do not strike the balancer on the outer part and use a piece of wood/soft metal in between! RigMan |
| RE: Chevy crank dampner Thanx Ringman I have looked at it, and it seems fine the hammering has distorted one of the edges but there are no cracks apparent and the rubber seems fine. I will use a bit of wood to re-fit it and mk 1 knockonmeter Thanx Kelvin |
| RE: Chevy crank dampner Hi Kelvin to remove the damper you need a steering wheel/vibration damper puller, see below. Hope this helps, Norm |
| Chevy V8 Crank | claude3c | Engine Tech Tips & Questions | 7 | 17-06-07 07:44 PM |
| Which harmonic dampner? | Andy302 | General Tech Tips & Questions | 3 | 11-04-04 10:25 AM |
| chevy stroker crank | StuartB | General Cobra Discussion | 2 | 30-03-03 04:52 PM |
| Chevy Crank Damper Installation | choogh | General Tech Tips & Questions | 1 | 04-04-02 10:53 PM |
| Chevy Rods and Crank | cobra_dude | General Tech Tips & Questions | 1 | 28-07-01 05:45 PM |
