Results 1 to 6 of 6
  1. #1
    tonym's Avatar
    tonym is offline Driving God
    Join Date
    Apr 2004
    Location
    on the edge...almost falling off
    Age
    50
    Posts
    6,013
    Electrical help required
    I've wired my indicators as simply as I can as per the drawing below (there are front and rear indicators as well as repeaters and dash lights for each side) and I'm having a problem I can't solve. If I turn on the left indicator then all is fine but when I switch on the right indicator then the flash is of the correct frequency but very short in duration. If I use the hazards then all lights work perfectly. I've tried changing the relay and the switch and taking the wiring away from the hazard switch but it's still the same. My thoughts are if there's a wiring fault then why does it work OK on hazards?? Any pointers as on where to look would be helpful,
    Bugger, it won't let me attach the drawing
  2. #2
    wilf is offline Banned for owning a STAG!!! Pit Babe Magnet
    Join Date
    Jan 2001
    Location
    On the naughty step
    Posts
    13,783
    Tone, it's totalled and there is no cure.
    Crendon has left the building................bright yellow Stag has landed.
  3. #3
    kdavies3's Avatar
    kdavies3 is offline Driving God
    Join Date
    May 2004
    Location
    Cowbridge, Vale of Glamorgan, South Wales.
    Age
    55
    Posts
    6,879
    Tone the fast flash would normally occur when a bulb has gone, obviously it hasn't as the hazards work OK.
    The suspicion I have is that there is a high resistance issue or maybe a bad earth somewhere?
    Kev Davies
    South Wales Area Rep.
    DAX Mk4, 383 Chevy Stroker, Tremec. SOLD
    Contemporary CCX 3-4028, 445ci Big Block FORD FE, Old School Now Running and Driving
  4. #4
    oglyoodoo's Avatar
    oglyoodoo is offline Head Mechanic
    Join Date
    Jun 2003
    Location
    Brackley, Northants, England.
    Posts
    679
    As you have eliminated most things that can go wrong I would start by checking that each lamp is in fact drawing the correct 21W or thereabouts as the flasher rate and possibly the on time will be critical to the load when indicators only are in use. Try swapping left and right indicator lamps to the opposite side and see if the problem changes side.
    When on Hazards there is no lamp fail indication as the current drawn by 4 21W lamps, plus tell tails, exceeds the Indicator lamp fail threshold in the flasher unit so the hazard flash will always be at the correct rate. (Unless three lamps fail of course!)
    Denis
    GD427E039
  5. #5
    tonym's Avatar
    Join Date
    Apr 2004
    Location
    Age
    50
    Posts
    6,013
    Ok, after much searching and car dismantling I have found that removing the repeater lamp on the offending side cures the problem even though it lights up and flashes the same as the other lamps on that circuit. I shall now try and work out why
  6. #6
    tonym's Avatar
    Join Date
    Apr 2004
    Location
    Age
    50
    Posts
    6,013
    Quote Originally Posted by tonym View Post
    After even more searching, I found that one of the side repeaters I bought from SVC at Stoneleigh had a 4W bulb, the offending one had a 34W bulb!! Problem solved, just need a "Big Tone chat" with SVC at Newark
    Thanks for the pointers everyone!
  1. Electrical Whizz required
    By davidlatimer in forum General Tech Tips & Questions
    Last Post: 15-01-09, 09:50 PM
  2. Electrical Fun
    By Lloyd Barnes in forum DAX Technical Questions
    Last Post: 30-12-08, 07:59 AM
  3. TKO 500 Electrical
    By Toddy in forum General Tech Tips & Questions
    Last Post: 13-01-08, 04:05 PM
  4. Electrical gremlines
    By kurrmet in forum Engine Tech Tips & Questions
    Last Post: 12-05-06, 11:29 PM
  5. Engine Electrical
    By Rupert in forum Engine Tech Tips & Questions
    Last Post: 30-11-04, 09:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
