| DAX Body I've just gone to fit the body on my dax but it doesn't line up too good. I had to extend the slot for the handbrake braket to get the body over it. Is this a common thing or is it because the body isn't forward enough because of the ali bulkhead. I did get it on in the end after extending the slot for the handbrake but am a bit concerned as if I fix the tube down other things might not line up later in the build. |
| RE: DAX Body Now now Dave I thought that the forum in general had decided not to make insinuations about other manufactures. I built a Sumo and apart from fitting the doors I had no problems with the rest of the build. Value for money the Sumo can't be beaten. Mike x( x( x( }>
| RE: DAX Body Hi Mike. What about drilling the galv. out of all the holes. drilling all your own light holes. Trying to get the body centralised. Packing the sills. Tryig to get the Cortina door catches to fit inside the doors around the exess matting. Not just filing/grinding bits off the doors but having to cut bits off to make them fit so that you can open them in addition to all the mither with the hinges. Did yours have a bonnet that had been left in the mould long enough or did you have to add 1/2 an inch of filler around the bonnet scoop because it had "sunk" Did you have to put your screen rubber in upside down to get it to reach the scuttle. Did your inner wings fit. And once fitted did they catch the tyres on full lock. C'mon, if it was that good why have you now got an AK? Am i whinging here? Having said all this i do like the Sumo but only as a budget build, i wouldn't recommend anyone "over specing" the car for future value reasons.
| RE: DAX Body Take it you don't sleep very well Dave looking at the time of your post . The bloke was happy with the bellhouseing . Regards Steve T |
| RE: DAX Body Dave Had to drill out galv, correct drill for lights, correct body centralising, packing sills, fitting door catches, filling and grinding all comes under fitting of doors, cause you have to fit the body to match the doors. Bonnet fitted near perfect. Screen fitted perfect. Inner wings fitted but they are both different shapes, Yes I had to recess the near side inner wing, wheel did touch. But as I said, you gets what you pays for. Ive built an AK, because I wanted a Chevy, I did'nt fancy putting all them horses in a Sumo chassis and as you said I woud'nt recommend anywhon else does. Mike
| body about to go on! | steve_h | General Cobra Discussion | 2 | 17-03-07 09:38 PM |
| body on | servistar | General Cobra Discussion | 12 | 28-12-06 01:23 PM |
| Body on - looks like a car now | pelham939 | Pilgrim Sumo Technical Questions | 11 | 26-05-06 01:30 PM |
| Dax body | mikeb | DAX Technical Questions | 7 | 20-09-03 07:05 PM |
| GD Body-off & on | Mclaren | General Tech Tips & Questions | 6 | 12-09-03 01:14 PM |
