Old 10-06-02, 02:29 PM
kdavies3's Avatar
Clutch Pipework Chevy and Tremec
Hi Guys,
just a quickie I hope using a 7/8" master and slave cylinders as I am (once again thanks to Dave Brookes for the advice).
What size clutch pipe should I use? I'm thinking of 5/16" but before I take the plunge and start flaring I thought I'd take advise.
On a complete tangent do I need to have side repeaters for the good old SVA? I have seen lots of pictures of cars without or are they pre SVA?
Dax's lighting kit doesn't come with side repeaters.
If it ever arrives I'm so looking forward to fitting the Dax side exhaust system (NOT!) following recent posts.
Kev Davies
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 10-06-02, 06:02 PM
RE: Clutch Pipework Chevy and Tremec
Kev - 1/4" pipe should be OK.
You will need side repeaters for SVA. Any cars that no longer have them had them removed after SVA!! Disgraceful
Wilf
Old 10-06-02, 07:30 PM
Kev
Dax do a braided pipe kit for the Dax/Tremec setup. It has a banjo set up which you will need for the access to the top of the cylinder and depending where your slave sits, to clear the tunnel. Its not cheap, but the saving you will make from making up the part is a couple of quid. Its length is ideal so it may be worth you getting one from them to save the hasstle. Thats if your master is an AP.
Mike.
Old 11-06-02, 01:08 PM
kdavies3's Avatar
My master cylinder was supplied by Dax (it's a Tilton) my slave is a Discovery item.
I'm in the throws of making up a bracket to mount the slave close to the oil filter, I must admit that using a Mcleod steel safety bell housing does make it tight in the tunnel area, I've already shortened the clutch lever by an inch.
If there's a next time I think it'll be the more normal bits from Repower.
Thanks for the help guys
Kev Davies
Kev Davies
South Wales
Old 11-06-02, 01:53 PM
Hello Kev
I used the larger bore pipe, told that it allowed the fuild to return quicker
and reducing chance of clutch slip, not all may agree but I did.
As for pipes take your time and all will be OK.
The wiring is in the loom for the side repeters,Not all people like the ford
side repeters thats why dont enclude them.
Cheers paul.:7
srv8 with tremec 5 spd and 351w clutch problems milanomonster General Tech Tips & Questions 0 28-07-04 05:04 AM
Clutch Master Cylinder Pipework Barry Davolls DAX Technical Questions 6 16-03-04 10:42 AM
Small Block Chevy with Tremec Clutch Arm Query wilf General Tech Tips & Questions 3 07-11-02 08:25 PM
Chevy, tremec and 3.07 diff? chris m General Tech Tips & Questions 3 18-02-02 08:22 PM
Clutch Choice for Tremec Fitters mikey General Tech Tips & Questions 3 17-12-01 06:33 PM
