Old 10-06-02, 09:29 PM
Early Dax Mastercylinder
I have an early Dax registered '88, fitted with a pedal box with the clutch master cylinder bolted to the front of the footwell not the top.
The brake master cylinder/servo unit is past saving and needs to be replaced. Anyone any idea what was originally recomended by Dax?
Old 11-06-02, 01:17 PM
kdavies3's Avatar
RE: Early Dax Mastercylinder
Sorry to state the obvious David but I would suggest you ask the boy's and girls at Dax, they are always very helpful, I'm sure someone there will remember what they used to fit nearly 15 years ago.
Dax phone no. 01279442661
Kev Davies
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 11-06-02, 01:30 PM
Dave is the servo mounted on the front crossmember.
at this time dax used a remote servo in this position.
If not it may be that the orignal builders own spec.
Do you now the age of your chassis, As it may be alot earlier than the
registered date.
Have you tryed speaking to peter walker at dax, If you have your chassis number
handy he will be able to date it and answer your questions.
all the best
Paul.
Old 11-06-02, 09:14 PM
If its mounted on the opposite side of the footwell and bolts through to the pedal frame its from the VW Golf Automatic combined servo/master cylinder. However the Ford Escort master cylinder will fit to the Golf servo and dosent have the sponginess of the Golf.
Make sure you get the Automatic version though.
Just check because I bet you can fit the Escort Servo if you use the same master.
Mike.
Old 11-06-02, 09:23 PM
Thanks for all the advice.
David
early SRV8 denis84 General Cobra Discussion 45 05-09-06 08:34 AM
Early in't it steamyrotter General Cobra Discussion 6 30-04-06 08:11 AM
Xmas come early dman General Cobra Discussion 29 03-12-05 02:36 PM
MGB MASTERCYLINDER Clarkson General Tech Tips & Questions 27 14-08-03 12:31 AM
Early Dax roll control General Cobra Discussion 5 15-12-02 01:22 PM
