Results 1 to 7 of 7
  1. #1
    Dixie's Avatar
    Dixie is offline Chief Engineer
    Join Date
    Apr 2007
    Location
    Shepton Mallet,Somerset
    Age
    45
    Posts
    1,071
    RV8 sump for Vitesse
    I need a new sump for my RV8 motor(Don't ask!!!)
    Will SD1 one fit? are they all the same?
    Thanks M
    DAX with 3.5Ltr Rover Vitesse V8, XJS running gear. AND 20MPG.
  2. #2
    Paul B's Avatar
    Paul B is offline Chief Engineer
    Join Date
    Dec 2001
    Location
    Bristol.
    Age
    53
    Posts
    1,293
    Hi Mark
    If you are looking for more ground clearance, go for a Range Rover one complete with oil pickup tube. It's about 10mm shallower than the standard SD1 sump.
    Paul
  3. #3
    Dixie's Avatar
    Join Date
    Apr 2007
    Location
    Age
    45
    Posts
    1,071
    Thanks for advice Paul.
    M
  4. #4
    craggle is offline Driving God
    Join Date
    Oct 2003
    Location
    Southwater, West Sussex
    Age
    36
    Posts
    9,866
    An SD1 sump will fit but they are a bit hard to find now whereas Range Rover ones are easy to find and as Paul said they are slightly higher. They do hold more oil though so oil change prices will increase slightly.
    Is the sump completely beyond help, Can it be welded or brazed again?
    Polishes to date = On hold.
  5. #5
    Dixie's Avatar
    Join Date
    Apr 2007
    Location
    Age
    45
    Posts
    1,071
    Yes I can mend the sump, but don't want to be without car so I thought buy another one because it's easy to change, and then repair old one at my leisure.
    Also with the new one I can add a sump guard. Where I live those Council plonkers have installed sleeping policeman every 50m, I called highways because I am sure they are too high, guess what? They don't want to know.
    M
  6. #6
    Dixie's Avatar
    Join Date
    Apr 2007
    Location
    Age
    45
    Posts
    1,071
    Can anyone tell me if the sump is made from Alloy or steel? Can it be MIG welded?
    I have not got a magnet to check plus I am at work so couldnt check anyway.
    Depending on answer is what I do next.
    ta M
  7. #7
    russell_ram2 is offline Chief Bottle Washer and Tea Boy
    Join Date
    Aug 2011
    Location
    Birmingham
    Posts
    114
    Quote Originally Posted by Dixie View Post
    SD1 sumps are steel, and yes, MIG would be the easiest way of welding it as it's slightly more contamination tolerant then other methods.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
