Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    tommy-boy's Avatar
    tommy-boy is offline Head Mechanic
    Join Date
    May 2008
    Location
    Costa del Newcastle upon tyne
    Posts
    997
    Rear hub spacers
    Evening guys
    Could I ask some advice on rear hubs
    I spent the day fitting the loom to my AK, and started to bleed the brakes. As I jacked the car up the rear nearside wheel was slack... Very slack. I investigate the issue by firstly removing the wheel, and the whole hub had a good amount of movement, yet the castle nut was tight and split pin fine. I removed the outer pivot shaft and removed the whole hub and carrier off. When I inspected the back of the hub something is very wrong. The oil seal has been badly chewed up and the alloy hub carrier has been getting scared from the drive shaft. I will get some pictures tomorrow to help explain what I mean.
    My hubs were sent to Ed at Ward, and will probs have to go back now. I'v spent some time thes evening refuring to Haynes manual along with some systematics from SNG etc... It seems I'm missing something surly? But can't find out what.
    Should they be space out off the drive shafts slightly? If so this would explain my excessive amount of shims to achive an acceptable camber.
    I will get some pictures tomorrow, but my initial thoughts were the ABS ring was not in to act as a spacer, but the ABS ring is between the inner and outer bearing and its the inner bearing that is getting the greef.
    The running gear is XJS 1989 with ABS originally.
    Any help or advice from the forum of knowledge?
    It's alive!!!! Whahaha haha. I'v created a monster!http://tommysak427.blogspot.com..……Because I'm classed as young I am inferior, I must respect my elders, especially the ones with a full garage!!!
  2. #2
    seph's Avatar
    seph is offline Chief Engineer
    Join Date
    Mar 2008
    Location
    Coventry
    Posts
    1,269
    Tommy,
    you should have a spacer hat goes on the driveshaft before the hub is attached. It is concaved on one side and flat on the other, It is about 1 1/2" in diameter and about 1/4" thick. The flat side faces the hub.
    Paul
    AK, Huddart 383 stroker, IVA passed, On the road 27/10/12
  3. #3
    tommy-boy's Avatar
    Join Date
    May 2008
    Location
    Posts
    997
    That sound correct mate.
    I certainly don't have that.
    Have you got a part number mate?
    I can't see it on any diagrams.
  4. #4
    seph's Avatar
    Join Date
    Mar 2008
    Location
    Coventry
    Posts
    1,269
    CCC6807 I think.
    Paul
  5. #5
    tommy-boy's Avatar
    Join Date
    May 2008
    Location
    Posts
    997
    Are these the bad boys you were refuring to mate?
    http://item.mobileweb.ebay.co.uk/vie...w=160856666006
    On fricken eBay..... I hate eBay with passion.
  6. #6
    Purple AK is online now Pit Babe Magnet
    Join Date
    Aug 2011
    Location
    East Sussex
    Age
    61
    Posts
    14,966
    It's the called the "seating ring for the oil seal" it goes on the driveshaft first, then the spacer shim before you put the shaft through the hub. Barretts mis-describe it on the XJS diagram! But it's part#CCC6807 in the XJS one so should be the same.
    Jaguar XJS Parts Catalogue Page 28 #13
    AK427 351Cleveland T5WC
  7. #7
    seph's Avatar
    Join Date
    Mar 2008
    Location
    Coventry
    Posts
    1,269
    No mate, thats not them. I was missing one and they are about £30 each to buy. I got one from Wards for much less than that. You will probably only need to replace the oil seal on the rear hubs, I did on the one that was damaged.
    Paul
  8. #8
    tommy-boy's Avatar
    Join Date
    May 2008
    Location
    Posts
    997
    Cheers guys.
    I will give Ed a call on Monday, see if he has a couple.
    Im going to replace both the oil seals Paul. One is totaly destroyed and one is scuffed and will contaminate the bearing if used, so there both going.
  9. #9
    TINKA is online now Driving God
    Join Date
    Apr 2004
    Location
    East Leake, Nottinghamshire, England.
    Age
    48
    Posts
    5,823
    It's a long time ago since I did this on mine, but isn't this the spacer that adjusts the end float. If so it might not be just a case of ordering a replacement. I know when Wards did mine they made a big point of telling me not to get them mixed up.
    Martin
  10. #10
    tommy-boy's Avatar
    Join Date
    May 2008
    Location
    Posts
    997
    I don't think so martin. From what I can see the spacer that controlls the endfloat has to be mated to a flat surface, hence this bit I'm missing. If not it will just be up against the radius edge of the drive shaft and not give any clearance, thus my knackerd oil seal. I will be having a good chat with Ed first mind. Because I don't want a visit from Mr Cockup! ......again!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
