| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM Yeah I got the same problem, so I used a 2.5 " filter (instead of 3" recommended) and solved it. Though the top of air cleaner is very close to primary area and may limit air flow slightly and I would have to shorten one of the vertical return pipes (think they are over flow pipes in case of a flood etc) These lower paper filters were easily available for under a tenner. Graham
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM I tried the low riser (2") and totally fouled my carb so I have it as spare if any one wants it. You can buy a spacer from real steel though and space it up. Its a case of mucking around with various combinations. You could lower the engine and get a 7.5 " kicked out sump but is expensive way of doing it. Graham
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM edlebrook make an chrome filter which is dished and it sits lower over the carb. my dax with 350 chevy + holley & rpm performer & high rise bonnet has a good 2" clearance, What type mounts are using. Regards Paul. |
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM I have a spare 3 inch low rise filter & housing that definately fits on the RPM in the chevy/dax If you're going to duxford let me know & I'll bring it along steve
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM Kev Have a look at the top and bottom of the air filter, and look at the depth of the join on the rubber to the element. You might have enough room lower the profile of the air filter by cutting away the surplus rubber on the top and bottom of the filer element. After you have cut this away if possible, lay some cling film on the filter housing, then put some mastic around it and place the filter on top of the mastic. This will form an air tight seal between the modified bottom and top of the filter and the filter housing. This is obviously dependant on how much you can cut away. Robert Forum Admin http://www.cobraclub.com/flags/UK.gif
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM Nice One Steve! I surely hope to be at Duxford, I'm at a BBQ in Birmingham on Saturday night but I intend to do the trip, South Wales to Birmingham, Birmingham to Duxford on Sunday and Duxford to South Wales Sunday pm. My mobile no. is 07730 923556. please give me a call on Sunday or I'll ring you if you let me have your no. :7 cheers Kev Davies
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM mobile 07860 151387 Steve
| RE: Bonnet Clearance - DAX SB Chevy Edelbrock Performer RPM Kev, two comments I have similar underhood clearance probs. I have fitted the Mr Gasket low riser over my Holley 600 and it fits fine - you just need to remove the choke flaps that you don't need anyway. I also have in my garage a Holley Contender inlet manifold in good condition and hwich is a fair bit lower than the Edelbrock Performer RPM - which is quite high. Let me know if you are interested and I can bring it over to Duxford - it is for sale. Regards Nigel B
| Edelbrock Performer Manifold | martin_t | General Tech Tips & Questions | 18 | 10-08-06 10:48 AM |
| Edelbrock Performer RPM heads - SBC | mclark | General Tech Tips & Questions | 3 | 02-05-04 11:14 PM |
| Edelbrock Performer 289 manifold | 427sc | General Tech Tips & Questions | 4 | 25-04-04 11:53 PM |
| edelbrock performer manifold rv8 | markg | General Tech Tips & Questions | 9 | 16-08-03 08:55 PM |
| Edelbrock Performer RPM | Glyn_Turner | General Tech Tips & Questions | 9 | 03-06-03 02:12 PM |
