Old 20-08-02, 05:54 PM
simon's Avatar
water temp sender
Is it possible to test this?
i have it out of the car and I have a multimeter....what should I test for (if I can)
Thanks
Simon
Old 20-08-02, 06:12 PM
robert's Avatar
Administrator
RE: water temp sender
Simon
Put a power source to the sender and a guage, and stick it in a pan with a cooking thermometer. If memeory serves me correctly, if you don't put a voltage stabiliser on it, it will read slightly off.
Robert
Forum Admin
Best Regards
Robert
Old 20-08-02, 10:00 PM
Robert
agree with the practice discribed.
but does it not depend on what type of gauge you have as to whether
you need a voltage stabiliser?
if you have a smiths gauge you probably would ?
Steve:7
Old 21-08-02, 03:17 AM
simon's Avatar
it's an ICKNIELD gauge.....
Old 21-08-02, 09:56 AM
maxGD059's Avatar
Simon
When I needed to check my water temp. guage & sender, I sent them to Speedy Cables. The turn around was very quick & charge small. This saved farting about with boiling water & the misses moaning about her best saucepans getting grubby!!!!
Richard
(It'll only be a 5 minute job)
Old 22-08-02, 12:10 AM
Simon
Basically your temp sender is a resistor that changes resistance with heat. As it gets warmer its resistance decreases. So when its at room temperature it should read around 1000 - 5000 ohms, depending on what sort it is. When you plonk it into boiling water it should read around 100 - 500 ohms. As long as it decreases with heat, its unlikely to be faulty.
Phil
5.0L TVR EFI Power
Water Temp Sender Problem BenBaron General Tech Tips & Questions 4 15-06-06 09:19 AM
Water temp sender JonnyT General Tech Tips & Questions 12 02-05-06 03:28 PM
Water temp sender. tony General Tech Tips & Questions 3 02-03-05 05:31 PM
water temp sender thread craigh Engine Tech Tips & Questions 0 19-06-04 02:10 PM
Water temp. gauge/sender question ian General Tech Tips & Questions 6 31-07-03 10:21 PM
