Old 02-09-02, 04:36 PM
Slight Pull to Right on Brakes
I've just got through the SVA and registered. I've had an MOT and all was OK on both tests. I'm sure I could find the readouts from the SVA test if I needed to but I've got a slight pull to the right under braking.
I had much more brake dust on my right hand wheel when I cleaned them last night too. It's only a touch and the brakes are all new.
Should I just live with it for a bit and see what happens?
Like I say it's not much.
Vince
Time served Auto Electrician
Lucas Leeds 1979-1983
Old 02-09-02, 05:32 PM
robert's Avatar
Administrator
RE: Slight Pull to Right on Brakes
Could just be the calipers and pads starting to bed in, but it would be a good idea to re-bleed the brakes as some air bubbles might have formed. I would be tempted to leave it for now other than the bleed.
Robert
Forum Admin
Best Regards
Robert
Old 02-09-02, 07:46 PM
Try pushing harder on the left hand side of the brake pedal to compensate!:7
Sorry couldn't help it.
Old 02-09-02, 07:57 PM
kdavies3's Avatar
I wonder if something in the suspension may have settled throwing your geometry out slightly, now you've done a few miles?
Just a thought
:7 :7
Kev Davies
PS I've sent you home e-mail to try that file again.
cheers
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 03-09-02, 12:32 AM
Thanks Rob. Yeah, I'll do that. I used an easy bleed and all was OK. I'll do a little press on it son..... tomorrow.
Ronnie.... your maaaaaddddddd.... it's a manual. There's no way that the brake pedal can distinguish weather I'm putting pressure on the right or the left side of it.
Now my mother in law has got an automatic fiesta. If I was to remove that big pedal from her car... that may make the difference. Thanks for the tip.
With a big pedal. Pressing on the left or the right might just make the subtle difference required.
Wow. Such top blokes in here or what.
Vince
Old 03-09-02, 02:10 PM
Vince - wot Rob said, bleed 'em to make sure, check tyre pressures, maybe swap front tyres over, but they might just take a few more miles to bed in yet.
After that, if it's still doing it, look to the geometry, after double checking ride height - those springs will settle in the first few hundred miles.
Wilf
Old 03-09-02, 06:02 PM
russell_ram's Avatar
Club Treasurer
"maybe swap front tyres over"
But not if they're directional like those ZZ1 's you and me run Wilf, else they'll end up going backwards.
Russ
Old 03-09-02, 08:36 PM
dave's Avatar
BIG hug.
Vince.
If the "Easi-bleed" gadget you used was one of those that connects to your tyre then i would be tempted to bleed them up by the traditional method.......Your missus on the pedal and you under the wheel arch. As i have never had a perfect result from using one of those things.
P.S. Does anyone want to buy one for a fiver?....... (d'ya get my drift)
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 03-09-02, 09:52 PM
Score one to the ramming one. Naturally I meant that???
Wilf
Old 03-09-02, 10:17 PM
Miket's Avatar
Fully Paid Up Grandad
I'll second Daves comment on Easi-Bleed, they are hopeless, I did exactly what you recommended, got the missus on the pedal but she miss-interpreted the pump hold, pump hold, up down, up down, hold, never known it to take 2 hours to bleed at set of brakes.
Mike
AK 427 FOR SALE
AK427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
351 Windsor wont pull after 3k...help cobra351w Engine Tech Tips & Questions 7 24-05-07 06:04 PM
Slight problem with Jag running gear rlagden Newbies 1 03-11-05 07:27 PM
Slight dink in new cam bearings... Andy302 General Tech Tips & Questions 5 07-08-05 07:25 AM
Pull your fingers out!! robert General Cobra Discussion 2 11-06-03 09:42 PM
Slight changes coming up robert Admin Announcements 6 15-10-02 06:03 PM
