| Camber, Caster and Toe-in numbers for a DAX Hi gents and ladies, I am the proud owner of a Dax Cobra of 1986 that was imported by the Dutch representative at that time. (Number 6 build in The Netherlands). It is a second hand car that I bought from the first owner. I am doing several modifications (Change for a Chevrolet 350 c.i.d.Tuned Port Injection) and I have revised the front suspension (New bearings, nylon bushings, etc). At this time I need some help from you for a correct setup and alignment. Can you tell me what the correct numbers are for? Caster Camber Toe-in Recommended Tire Pressure for “Front 215/60 R15 tires” “Rear 255/60 R15” I hope that you want to help me to make my Dax Cobra a perfect driving machine.
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement"¯ means that you recognize previous mistakes! |
| RE: Camber, Caster and Toe-in numbers for a DAX I think the numbers you require are the back of the Dax build manual, I have it at home but not with me. I'm sure Dax will tell you if you give them a call. If not I can dig them out for you later. Kev Davies
| RE: Camber, Caster and Toe-in numbers for a DAX Hi for chassis prior to 1995 its Front Camber: 7/8 degree of neg on 15" wheels (3/8 degree neg 17") Rear Camber: 1 degree neg on 15" wheels (1/2 degree neg 17") Front toe: Zero Front Castor: Fit all 3 shims at the front Adjust if error > 1/2 degree Rear toe: 10 - 30 degrees in. Tyre pressures 20psi Sizes 215/60/15 front 235/60/15 rear Hope thats a help Phil
| RE: Camber, Caster and Toe-in numbers for a DAX No sadly I don`t have a cobra yet I must first finish off my house then search for a garage to buy. I hope next year to be able to order a kit - I really want a Gardner Douglas but I know I won`t have the same help from GD as I would have from DAX when it comes to registering etc. I have heard that registering here is very difficult and some people transport their kitcars to UK for SVA and reg then bring them back here and swap over to Dutch reg (I don`t yet know how true that is?) Anyway I hope I can do the test drives next year and then decide between GD and DAX. Until then I can still keep dreaming !!
| RE: Camber, Caster and Toe-in numbers for a DAX Thanks for your point. It will be fun a Cobra with 30 degrees! regards, Cobra289
| RE: Camber, Caster and Toe-in numbers for a DAX "Front Castor: Fit all 3 shims at the front Adjust if error > 1/2 degree" Thanks Phil, This is what I need. One question, I think that I need to buy from Jaguar the shims because I have discarded the old ones. (Jaguar part No. C.15308- 6 units) Doe you mean “if error less than ½ degree between left and right” or the result angle measurement should be maximal ½ degree? Thanks in advance Phil. Regards, Cobra289
| RE: Camber, Caster and Toe-in numbers for a DAX An e-mail was send to DAX with the same request but till today no re-play. Dax build manual was not part of the package when I bought the Cobra. The previous owner was not interested in mechanics and order in Holland a complete build, so no manual in my possession. thanks, Cobra289
| RE: Camber, Caster and Toe-in numbers for a DAX >No sadly I don`t have a cobra yet >I hope next year to be able to order a kit - I really want a Gardner >Douglas but I know I won`t have the same help from GD as I would have >from DAX when it comes to registering etc. Four years ago the importer of GD in Holland was a member of the Dutch Cobra Club, hi has designed and installed my LPG gas installation. Autogas apparatuur BV. Cockeveld 6 5672 AE Nuenen (Eindhoven) Tel. 040-832850 >I have heard that registering here is very difficult and some people >transport their kitcars to UK for SVA and reg then bring them back >here and swap over to Dutch reg (I don`t yet know how true that is?) The registration is very difficult that is the reason why I bought a second hand. Be careful and only if you know for 300% sure what it cost and what to do, than you can take the decision. (BPM cost BTW cost etc.) >Anyway I hope I can do the test drives next year and then decide >between GD and DAX. From all the Kit Cobras is CRENDON the best “Replica” from the UK. I don’t know if it drives better etc. but it is the nearest reproduction to the real thing and that is the meaning of the word “Replica”. Check this address and enjoy. http://dialspace.dial.pipex.com/town.../homepage.html Like every body first dreaming and then “Klaarkomen” (There is always a way) >Until then I can still keep dreaming !! regards, Cobra289
| Pilgrim Camber and Caster angles | peterol1 | Pilgrim Sumo Technical Questions | 15 | 06-01-08 09:03 PM |
| Caster & Camber tool for YOU | Cobra289 | General Tech Tips & Questions | 1 | 17-06-05 11:29 PM |
| Another dim question about rear wheel Camber & Caster | Grease Monkey | General Tech Tips & Questions | 4 | 14-04-04 11:31 PM |
| Caster & Camber Setting. | mikey | General Tech Tips & Questions | 10 | 18-02-02 01:44 PM |
| camber and caster setup | simon | General Tech Tips & Questions | 3 | 16-06-01 07:12 PM |
