Old 23-09-02, 07:55 PM
Cobra289's Avatar
Side Screens and FOAM
Hi all,
Side screens supports on my old Dax Cobra have broken the inner layer of the door.
At that time ('86) the side screens from Dax where fitted to the inner layer by threaded knob with a T member welded to the screen.
The forces and moments where past to the polyester inner layer resulting in a rupture through the all length of the door.
I WANT TO CHANGE THIS.
So my question is:
Do someone experiences some paint cracks at the side screens guides?
How you install the guides? Just drilled? Of have you reinforced internally?
I consider reinforcing with PUR foam (Construction polyurethane foam)
Are there some experiences with foam?
Thanks in advance.
The Netherlands
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
Old 23-09-02, 09:33 PM
Miket's Avatar
Fully Paid Up Grandad
RE: Side Screens and FOAM
I drilled the doors so the guides fitted in tight, I flatened the end of a piece of copper brake pipe, I then mixed enough body filler to fill the hole from the inside by putting the filler in with the brake pipe and lifting so it would fill the inner surface and then gradually build it up so it is thick, you need to add plenty of hardener to the filler so it will go off quickly, then gently push the guide into the hole and the filler will squeeze up the guide, let it harden for about 1/2 hour and then you can drill out the filler that is in the guide. The finished job is very strong.
Make sure you mask round the hole so body filler does'nt get on the paitwork.
Hope you can understand the explanation.
Mike
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 23-09-02, 10:30 PM
Miket's Avatar
Yes Cobra 289, your drawing shows exactly the principal I explaned.
Good drawing.
Mike
AK 427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 23-09-02, 10:31 PM
Cobra289's Avatar
Thanks Miket,
Cobra289
Cobra289 Gallery
Old 07-11-02, 09:28 PM
Cobra289's Avatar
Hi Miket,
Thanks for your answer I think that I understand your explanation.
I made a drawing to show what you are telling me.
Please correct me if I miss interpreted your mail.
It can help other people.
Regards,
Cobra289
Cobra289 Gallery
Side screens for a RAM andybrown Ram Forum 4 04-11-05 03:49 PM
dax side screens shiney General Cobra Discussion 0 17-10-05 05:44 PM
Side-screens ti Pilgrim Sumo Technical Questions 1 02-10-05 06:46 PM
Side Screens darbynp General Cobra Discussion 7 13-04-05 11:50 PM
Side Screens Kevin Smith General Cobra Discussion 16 17-06-02 08:58 AM
