Results 1 to 4 of 4
  1. #1
    Philip is offline Head Mechanic
    Join Date
    Oct 2001
    Location
    Norwich, Norfolk, UK.
    Posts
    544
    URGENT!! Jaguar V12 Timing
    Please help,a freind of mine has a dax with a jaguar v12 in it. The ignition developed a problem where by it wouldnt go above around 2500 rpm. Ive replaced the 30year old ignition system with a lumeition system. But now it coughs and pops out of the carbs. Im guessing the timing is out after fitting the new system, but Im also a little concerned incase I'v swapped a plug lead over by accident. Does anyone know the firing order for these? Also does anyone know the static timing for them as well? Please help, the cars in my drive and I would like to get it done asap.
    thanks in advance
    Phil
    5.4L SuperCharged V8D RV8
    MS3 ECU, running fully sequential fuel and spark
  2. #2
    simon's Avatar
    simon is offline Technical Director
    Join Date
    Feb 2007
    Location
    Essex, UK
    Posts
    3,467
    RE: URGENT!! Jaguar V12 Timing
    Phil,
    According to the Haynes manual, the timing for a V12 is
    10 degrees BTDC static or up to 750rpm.
    Firing order is 1a 6b 5a 2b 3a 4b 6a 1b 2a 5b 4a 3b (anticlockwise)
    a is LH bank
    b is RH bank
    WARNING: Translation of author's random thoughts may have resulted in the unintended introduction of grammatical errors, typos, technical inaccuracies, lies, propaganda, rhetoric, blasphemy, rambling, and/or exhibition of shocking levels of ignorance.
  3. #3
    GUMBALL is offline Head Mechanic
    Join Date
    Feb 2007
    Location
    Billericay, Essex, England.
    Posts
    703
    Hi Simon,
    Graham D tells me that you recently had your V12 (with webbers???) set up on a rolling road somewhere in Basildon??
    Who did you use and were they any good??
    Hope to see you at our next meet in October (if it's not too far for you to come!! :7 :7 )
    GUMBALL
    Too many idiots, not enough villages!
  4. #4
    simon's Avatar
    Join Date
    Feb 2007
    Location
    Essex, UK
    Posts
    3,467
    Gumball,
    Yep very good place called Swallow engineering, They specialise in Jags though, not sure if their rolling road will handle big amounts of power. I wasn't after a power figure as the car is a standard set up.
    I think I could struggle up there. Is there nothing going on before though? i would like to have a drive out with other cars.
    Simon
  1. Jaguar 3.6 XJS - Urgent Info required
    By Martyn-ak427 in forum General Cobra Discussion
    Last Post: 15-08-05, 09:32 PM
  2. Ford Timing and Timing light
    By ldtopham in forum General Cobra Discussion
    Last Post: 12-02-05, 02:28 PM
  3. SBC Timing - 2 timing marks on damper
    By jonbillings in forum General Tech Tips & Questions
    Last Post: 09-10-03, 06:37 PM
  4. URGENT - YOU MAY BE ABLE TO HELP
    By FELIX in forum General Cobra Discussion
    Last Post: 16-08-02, 02:43 PM
  5. SVA Guidelines Book - URGENT URGENT
    By robert in forum General Cobra Discussion
    Last Post: 27-03-02, 07:44 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
