Old 29-09-02, 12:43 PM
dave's Avatar
TO YOU, TO ME
RE: identity lineup for GD parts!
Hi Paul.
You know that i've never built a GD but can i guess before the knowledgeable crowd join in.
Top left.........Battery box.
Top centre.......Exhaust bracket.(Diff or rear valance area)
3Rd down left....Handbrake bracket (That is if GD use an XJS item).
Squares in centre.....Seatbelt anchorage spread plates.
Give up on the rest.
Please remember that these are only guesses and if no one else replies then call Andy at GD.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 29-09-02, 07:09 PM
The bottom two are aftermarket Chassis stiffeners.
Mike.
Old 29-09-02, 07:43 PM
robert's Avatar
Administrator
>Mike.
Do you want them for your Dax, as Paul won't need them. }> }>
Robert
Forum Admin
Best Regards
Robert
Old 29-09-02, 08:38 PM
U brackets mount over rear shocks for rollover bar brace (3rd leg)plus longer than std bolts. T brackets (Stainless) are for mounting head restraint pads on rollover bars. Other brackets appear to be correctly identified except for fuel tank straps which might just stiffen up a Dax driver but probably not help the Dax itself. My GD does not use a battery box - the thing is wedged into the side sponson with expanding foam. I am not convinced the 'battery box' is that at all. My GD ain't got one and it looks beefy enough to be a mod for a gearbox or diff fitting.
Old 29-09-02, 11:32 PM
dave's Avatar
TO YOU, TO ME
Did i do good then, under the circumstances?:+ :+
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 29-09-02, 11:34 PM
dave's Avatar
TO YOU, TO ME
Mikey doesn't need them either as his car has its rear nudge bar brackets incorporated into the chassis frame.}> }>
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 30-09-02, 01:05 PM
OK, got the low-down from Andy.
Thanks to all for the input.
top left - battery tray
below thet - two roll bar mounts, they bolt to the rear suspension mount.
below them - handbrake mount
bottom - fuel tank straps
top centre - exhaust mount, bolts to rear chassis via rubber strap.
centre - seat belt mounts/plates
below them - battery clamp strap
T-bars - Headrest mounts
top right - nudge bar mounts
Paul
GD Euro #51, brought from damp and rainy Tipperary to sunny Palm Beach
Old 30-09-02, 01:07 PM
Callum,
Thanks for the input. Andy says that indeed the tray is for the battery. It must be a revision to the kit.
Paul
Old 07-11-02, 09:28 PM
All,
I am sending this off to GD tomorrow but thought I would see how knowledgable you fellow GD owners are?!
Apart from the two brackets in the top right which I assume to be mountings for the front nerf bars what are the other brackets? :+
Exhaust now fitted along with chassis front extension frame(?), getting there!
Paul
Diff identity richard mason General Tech Tips & Questions 5 23-09-07 10:37 PM
Hawk vented disc identity dingocooke Hawk Technical Questions 20 31-01-07 08:48 AM
The Stig's true identity revealed Chimeara General Cobra Discussion 12 08-08-05 07:57 PM
Dax Clutch Master Cylinder identity? Barry Davolls DAX Technical Questions 2 02-05-04 07:30 PM
Rover V8 engine identity beanpole General Tech Tips & Questions 12 09-12-02 02:52 PM
