Old 08-11-02, 12:53 AM
Rover V8 clutch prob.
Good day,
Had a strange problem with my clutch recently. Noticed fluid level was low in master cylinder but wasn't dropping and clutch was fine. Few days later no clutch, looked in cylinder, no fluid, went to a garage and was told I needed a new master cylinder, at the same time they replaced the slave. Car went fine for about a month then I noticed the same bad feeling in the pedal, lo and behold, low fluid level! Topped it up. Haven't driven the car much since then. Where could the fluid be going, no apparent leaks.
Thanks
Old 08-11-02, 08:11 AM
kdavies3's Avatar
RE: Rover V8 clutch prob.
I would say that almost certainly it's leaking into the brake servo, I remember having the same problem many years ago on a Rover 2000.
The master cylinder is leaking fluid into the servo can which is why you don't see the leak. x(
If the servo gets full enough you could end up with fluid getting into the engine via the the vacuum hose, it sure makes a lot of smoke. x(
I think it's servo and cylinder off for you my boy. Repair or replace the cylinder and drain out the fluid from the servo.
Hope this helps. :7
Kev Davies
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 08-11-02, 08:41 AM
STEVE G's Avatar
Zeb
You dont say what clutch cylinder you have.
Have you checked inside the car for a leak in the rear seal?
Kev
On a Marina brake cylinder there is a small bleed hole behind the seals to stop fliud getting into the servo if the seals go.Make sure its clear when rebuilding it.
Steve G.
Regards Steve G
Old 08-11-02, 08:48 AM
russell_ram's Avatar
Club Treasurer
Kev,
If Zeb was talking about his brake fluid level, then I might be inclined to agree with your diagnosis. However, there is no connection between the clutch cylinder and the brake system/servo. Most likely, the fluid is either lying in the bottom of the bell housing and dripping out slowly or it's running down the inside of the bulkhead and lying in the footwell under the carpets. The clutch master does not hold huge amounts of fluid and you might not expect a 'puddle' under the car.
Russ
Old 08-11-02, 10:29 AM
kdavies3's Avatar
A good spot Russ,
My only excuse is that I did reply first thing and my first caffeine hit hadn't kicked in.
You're probably right about all the missing fluid being under the carpets. x(
cheers Kev Davies
Kev Davies
South Wales
Old 08-11-02, 11:31 AM
Club Treasurer
'my first caffeine hit hadn't kicked in'
Yep, I had two or three working by then! Brain cells on overdrive.
Russ
Old 08-11-02, 02:03 PM
Thanks guys,
Unfortunately I am not able to get at my car at the moment (stuck on a ship in the Caribbean, work, not pleasure) but I am sure there is no fluid leaking back into the footwell. The cylinder is a Rover part. I think the truth will come when I open up the garage in December when I get back and have a look, maybe after standing for 3 months I will get some better evidence.
Thanks again.
Old 08-11-02, 08:29 PM
(stuck on a ship in the Caribbean, work, not pleasure)are you sure it's not both
Old 09-11-02, 01:07 PM
Yep! 7 days a week, 10 hours a day, 4000 people wanting everything fixed YESTERDAY!!
Wilwood clutch cylinder prob kevchard General Tech Tips & Questions 2 20-12-07 06:49 PM
More Rover v8 clutch woes.... DrFelch General Tech Tips & Questions 18 09-09-06 10:38 AM
Rover Clutch Conversion beanpole General Cobra Discussion 1 27-07-05 12:20 PM
Rover V8 Clutch Woes!! Ranger Bob Engine Tech Tips & Questions 1 30-04-05 09:29 PM
ROVER SD1 CLUTCH davew General Tech Tips & Questions 10 23-02-04 08:15 AM
