Old 14-11-02, 02:19 PM
Speedo cable
Good day gentlemen
Looks like I need to replace my speedo cable.
How difficult is it? Do I need any special tools? Sorry for the stupid question..
The cable snapped right at the point of entry into the gauge.
Rover 3.5, smiths speedo. There is a tight squeeze just before it goes into the speedo.
Old 14-11-02, 04:01 PM
STEVE G's Avatar
RE: Speedo cable
Zeb
I used a standard SD1 speedo cable.Obviously the gearbox end is correct.I sent ages under the car trying to fit it,till I cut the back of my hand on a protuding self-tapper and found a small inspection plate.Lifted carpet from tunnel and VOILA screwed it on easy.The speedo end had a nylon clip assembly, which I removed and using PTFE tape on the speedo thread push fitted the cable to it.I now have a Smiths reverse drive speedo which has a screw on adaptor.the cable is pushed onto this the same as before.
You could try Speedy cables, tell them the two ends and length and they will price it.
Regards Steve G.
Regards Steve G
Old 15-11-02, 02:11 PM
RE: Speedo cable
Thanks Steve.
Speedo Cable Length lomondbob DAX Technical Questions 2 21-07-07 07:58 PM
Smith's to Tremec Speedo cable Dax SC General Tech Tips & Questions 3 17-03-03 08:07 AM
Speedo cable RV8 and Heater fan Zeb_1970 General Tech Tips & Questions 2 31-12-02 07:31 PM
Speedo cable drive RigMan General Tech Tips & Questions 3 03-07-01 09:25 PM
Speedo Cable RigMan General Tech Tips & Questions 2 27-05-01 09:47 PM
