  #11 (permalink)
Old 24-11-02, 02:50 PM
RE: Connections
>>But there is nothing wrong with my present loom
Hi Kelvin,
Sure but you will need some excuse to go to the garage, so why not the wiring. I write software for a living in a little known language of "ANSI C" but part of my job occasionally requires me to design Test Jig Looms. Wiring the car was good therapy. Here is the fuse and relay assembly, it fits up in the passenger footwell and is secured using dzus clips.
http://www.cobraclub.com/crcforum/user_files/655.jpg
All the best
Paul.
  #12 (permalink)
Old 24-11-02, 06:05 PM
RE: Connections
very very nice and neat, do you have the part numbers for the plugs ? as when searching through the rs web site i get a 1001 results, none of which seem to be the one i want .
Thanx Kelvin
  #13 (permalink)
Old 25-11-02, 09:16 AM
RE: Connections
Hi Kelvin,
Searches on Automotive reveal most,
These are some numbers to get you in the area, these are for 2, 3 and 5 way connectors Male and female along with pins and wire seals. The pins accomodate 1.5 and 2.5mm (Just) wire.
314-1198
314-1205
314-1227
314-1255
314-1261
314-1283
314-1328
314-1340
314-1154
314-1160
Good luck
All the best
Paul.
  #14 (permalink)
Old 25-11-02, 12:57 PM
RE: Connections
May I recommend buying solder type connectors with seperate insulators.
Most electrical problems are caused by bad connections. Soldering the connectors helps to prevent future problems.
  #15 (permalink)
Old 26-11-02, 05:13 PM
RE: Connections
Right Paul this i promise will be my last question,
What is the name of the connection at the top right of the picture. Its the like the ones that they use on car sterio's.
Thanks again
Last one i promise
kelvin
  #16 (permalink)
Old 26-11-02, 05:53 PM
RE: Connections
Hi Kelvin,
The square connectors are Quick Mate sometimes refered to as QM they are basically a bulkhead connector but work also as inline connectors. I use them for in car wiring because of the high pin density and relatively high current carrying capacity of 13A before any derating. Search the RS Catalogue for QM.
With regards to Vince's comments on soldering it has a lot to offer, where the joint is tied down and will not move or vibrate a soldered joint is very weather proof, however such connections as engine sensors etc which are subject to serious vibration are better crimped as crimped joints last longer before they fracture, I don't know why but it is a fact. And if you don't believe me I'll sulk!
Have a nice day
All the best
Paul.
  #17 (permalink)
Old 26-11-02, 06:20 PM
RE: Connections
Yeh the aircraft at work are the worst vibrating thing that i know and they have 95% crimp joints, i'm happy with them as i tend to over heat things
Ta vince / paul
Kelvin
  #18 (permalink)
Old 26-11-02, 08:13 PM
RE: Connections
I'm never flying again.
I simply speak from experience of fixing electrics on cars. Whenever you have a problem with bad connections these are the most common places to look, and usually find.
  #19 (permalink)
Old 26-11-02, 08:17 PM
RE: Connections
Right that does it, I'm sulking!
All the best
Paul.
  #20 (permalink)
Old 26-11-02, 08:40 PM
RE: Connections
Yep vince i do agree but solder joints do dry if not done correctly and some of the looms i work on have been working for 25 years. Imagine ford electrics lasting that long .
Kelvin
Holley 390 Connections - Help adrianj Engine Tech Tips & Questions 3 28-03-06 01:42 PM
Wiring - Last few connections bc_suv Pilgrim Sumo Technical Questions 2 13-03-06 10:49 AM
Waterpump connections Rupert Engine Tech Tips & Questions 10 07-04-05 06:16 PM
Connections! Phil McCann Engine Tech Tips & Questions 1 16-05-04 05:55 PM
For those with faster connections... Jules_ General Cobra Discussion 3 09-01-04 09:23 AM
