Old 01-12-02, 06:20 PM
Jaguar lower front wishbones
The lower wishbones on the jaguar front suspension are handed and
the dreaded Haynes manual does not say how they should be fitted.
i.e. should they be fitted with the lower balljoint fixing hole cranked forwards or backwards?
David
Old 01-12-02, 07:40 PM
RE: Jaguar lower front wishbones
Hi David, just a quick tip before you post, try searching for 'front wishbone' and you should easily find the answer without waiting for a reply ! Somebody asked this about 4 weeks ago.
Its cranked towards the front.
Good luck !
Marcus (AK Rv
Old 01-12-02, 07:54 PM
Banned
David, the lower front wishbone arms should have the bottom ball joint mount to the front of thje vehicle, although it looks better to the rear, as I myself found out to my peril!!
Start of with two or three spacers in the top wishbone arms between the ball joint, also once again to the front.
A point to remenber it would appear; if you are using series two suspension, the top arms are paired & handed, that is to say you jugle the 4 of them around until the casting lumps which are threaded; which normaly takes the bump stops are the same distance apart when you hold them together in pairs. I think I have that right.
Best of luck Eric.
Old 01-12-02, 10:12 PM
Many thanks to you both.
David
Jaguar Lower Hub Shaft Question martin_t General Tech Tips & Questions 2 17-09-07 07:34 AM
Rear Lower Wishbones MarkyC DAX Technical Questions 10 28-08-07 07:34 PM
Jaguar front wishbones richardd General Tech Tips & Questions 0 22-10-04 08:34 PM
Jaguar Upper and Lower Wishbones rover General Cobra Discussion 2 22-04-04 06:45 PM
XJS Front Lower Wishbones. SIMONF General Tech Tips & Questions 1 02-12-02 06:44 PM
