Old 30-12-02, 11:04 AM
Bleeding the Coolant system ?
Hello everyone
I hope you all had a great Christmas. Most of mine was spent putting my engine back together. Got it all back in and fired her up to break in the cam to the new lifters. No major problems but it was ruuning a bit warm ( i think ) it was running at about 95-105 Degrees.
I suspect that I have air in the coolant system, what is the best way to bleed the air out ?
I am running a 383 Chevy with a standard Dax coolant system (ali Rad).
Any advice greatly appreciated !!
Dave
Old 30-12-02, 12:39 PM
robert's Avatar
Administrator
RE: Bleeding the Coolant system ?
Dave
Where is the header tank in relation to the top of the rad?
Robert
UK CRC Forum Admin
Best Regards
Robert
Old 30-12-02, 12:47 PM
The header tank is the highest point of the system with the outlet being at about the same height as the top of the Rad.
Old 30-12-02, 01:00 PM
robert's Avatar
Administrator
Then you shouldn't get an airlock unless the feed to the the rad is lower than the top of the rad.
Did you do any other changes to the system?
Robert
UK CRC Forum Admin
Best Regards
Robert
Old 30-12-02, 01:04 PM
the feed from the header tank goes down to the pipe from the bottom of the water pump which then goes to the bottom of the rad. Sorry for being daft but is this the feed or the return ie which way round is the coolent pumped, from the bottom of the rad to the top or from top to bottom ??
Thanks for your help
dave
Old 30-12-02, 01:10 PM
russell_ram's Avatar
Club Treasurer
Always cold feed out to pump from bottom of rad - hot from engine into top of rad.
Russ
Old 30-12-02, 01:16 PM
In that case then the feed from the top of the engine is above the inlet to the rad.
So in theory I should have no air in the system, is there any easy ways of checking this ?
Thanks again
Dave
PS. What is the first event of the year as it is about time I got myself to one actually in the Cobra !
Old 30-12-02, 01:31 PM
robert's Avatar
Administrator
Empty the system out and see if there are any bubbles in it. }( }( }(
How far out is the current temp from your normal runing temperature?
Robert
UK CRC Forum Admin
Best Regards
Robert
Old 30-12-02, 01:43 PM
Yep I think I will do that. It is hard to say how much hotter it is because I have changed the temp gauge to a mechanical one as the electric one I had gave an inconsistant reading. The temp after running the car at about 2000 rpm for 20 minutes whilst stationary was about 102 degrees. Is this OK. ( this was during break in so maybe hotter than usual ?)
Dave
Old 30-12-02, 02:17 PM
robert's Avatar
Administrator
Usually between 98 and 102, but depends on the specifics of the engine etc.
Might be worth putting the old guage on temporarily as that is the one you have the old readings with.
Robert
UK CRC Forum Admin
Best Regards
Robert
Coolant system help TheUnixKid Pilgrim Sumo Technical Questions 5 05-07-05 11:31 AM
Bleeding brake system, Jaguar IRS etc tonyevans General Tech Tips & Questions 0 20-03-04 09:40 AM
Bleeding an RV8 cooling system alastaid General Tech Tips & Questions 5 11-01-04 05:20 PM
Getting Coolant into the System David Parkes Pilgrim Sumo Technical Questions 2 05-11-03 10:59 AM
It's bleeding!!! paulmj General Tech Tips & Questions 3 14-04-03 09:26 PM
