| Speedo cable RV8 and Heater fan Hi all, Need to replace my speedo cable RV8 into smiths speedo, the small square end (at speedo) has broken due to a poor path I think. Is it difficult and where can I source a cable? I think water has entered the fan on my heater as it makes an awful noise and sounds like it is about to grind to a halt, how do I access it and is it possible to overhaul the fan motor? One last question, probably need new tyres within the next few months, I live in Spain (very slippy roads), don't need super grip as I'm not too mad! Any suggestions and how much should I expect to spend? Thanks |
| RE: Speedo cable RV8 and Heater fan Hi Zeb Rimmer Brothers will sell a spedo cable and are based in Lincoln Phone No: 01522 568000 or www.rimmerbros.co.uk They do mail order and normally stock most things Hope this helps Martin :7 :7
| RE: Speedo cable RV8 and Heater fan Speedy Cables (London) Ltd 0207 226 9228 are the peaople for all things speedo related (re-calibrate, cables etc). Dax generally use on old design Smiths fan heater assembly. This can be removed from inside the car with the dash removed & diconnecting the heater hoses within the engine bay. Mine leaked & was easy to DIY fix with solder. For a new motor (if required) suggest you speak with Dax direct. Sorry cannot help with tyre selection. Only use the expensive high performance stuff myself. Baldric
__________________ Baldric |
| Speedo Cable Length | lomondbob | DAX Technical Questions | 2 | 21-07-07 07:58 PM |
| Rover SD1 5 speed box - speedo cable | NICobra | General Cobra Discussion | 1 | 26-07-05 10:49 PM |
| Speedo cable | Zeb_1970 | General Tech Tips & Questions | 2 | 15-11-02 02:11 PM |
| Speedo cable drive | RigMan | General Tech Tips & Questions | 3 | 03-07-01 09:25 PM |
| Speedo Cable | RigMan | General Tech Tips & Questions | 2 | 27-05-01 09:47 PM |
