Old 23-01-03, 12:32 PM
Ground clearance
I am just about to set engine/gearbox into chassis (Ram SC )and because i have fabricated engine mounting brackets.....what ground clearance should I be aiming for , from ground to bottom of sump??.......with all these speed bumps....every inch counts
cheers
dave
Old 23-01-03, 12:54 PM
kdavies3's Avatar
RE: Ground clearance
Hi Dave,
I don't know what engine / box combination you have have but the lowest point on a Chevy tends to be the bellhousing flange or the sump pan.
I guess you want to have at least 4" of clearance if possible, but don't go too high because you won't be able to shut the bonnet, especially if your using a high manifold / carb set up, like an Edelbrock Performer RPM or similar.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 23-01-03, 05:35 PM
simon's Avatar
Dave,
My 302 only sticks below the chassis about half an inch, so I have plenty of ground clearance. However my air filter JUST clears the bonnet scoop. If I had to do it again, I'd drop the engine another 3/4ths of an inch or so.
Simon
Old 23-01-03, 05:51 PM
russell_ram's Avatar
Club Treasurer
Dave,
RAM/Rover
Front ride height puts chassis rails @ 6" ground clearance.
Sump is 5" clearance to ground.
Lowest point is gearbox front x-member (not the mounting one) @ 4" ground clearance - this one does very ocasionally catch but it is stepped downward from the std straight one to clear the gearbox (coz I lowered engine from std position by 1".
Hope this helps
Russ
Ground clearance eng622 General Cobra Discussion 7 21-03-07 10:09 PM
Ground clearance fredo Pilgrim Sumo Technical Questions 11 30-09-06 05:55 AM
ground clearance tonym Pilgrim Sumo Technical Questions 3 03-03-04 09:47 PM
Ground Clearance Frosty Pilgrim Sumo Technical Questions 6 17-09-03 07:27 PM
Ground Clearance JohnW General Tech Tips & Questions 6 07-11-02 09:22 PM
