Old 15-02-03, 07:36 PM
Brake Caliper Size Fittings
Hi all,
Im looking at using some aeroquip fittings for my brake calipers and other bits and bobs but am a little unsure of the size of the fittings.
Im guessing but jag calipers are ususally 3/8 UNF?
Will the banjo type fittings do the job on these or do I need to use another type?
cheers
Ben
kreativejuice...
www.kreativejuice.co.uk
Old 16-02-03, 09:22 AM
RE: Brake Caliper Size Fittings
Be careful Ben
Don't think aeroquip hosing is SVA friendly, I may be wrong but I seem to remember that the way the hose is assembled using olives makes it illegal for road use
The fact that it is used in all forms of motorsport and is a tried and trusted product seems silly to me, O well what do I know
Pete
Old 16-02-03, 01:37 PM
B*gger.
Oh well thats that idea out of the window, Presumably the SVA rule only applies to the brakes though? and not the rest of the plumbing (oil hose, water, vacuum etc?)x(
kreativejuice...
Old 16-02-03, 05:23 PM
kdavies3's Avatar
I think it depends on the type of Aeroquip hose you have.
Mine passed the SVA last year with them fitted.
I believe there are a couple of types of hose construction with some being OK and others not.
Kev Davies
South Wales
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 16-02-03, 05:50 PM
What type have you got then Kev?
Do I remember rightly that the hose needs to have some sort of marking on it? or am I making that up?
cheers
Ben&V
kreativejuice...
Old 16-02-03, 06:33 PM
STEVE G's Avatar
Ben
If you have 4 pot calipers they are definitely 10 x 1.0 mm threads.
If you do use s/s fittings I bought part no.9975917 and copper washers A4516 direct into caliper.
No leaks but no brakes yet either.
'nother story to be told later.
Steve G
GE427-Rover 281ci.
Regards Steve G
Old 16-02-03, 08:42 PM
hi guys ,my ak went through sva on friday with that type of braded hose on ,got them from ken
mark (fat boy northern ):+ :+ :+ :+ :+
Mark (Fat Boy Northern)
Mark\'s gallery
Old 17-02-03, 07:55 AM
kdavies3's Avatar
Congrats on the SVA pass Mark. ~~ ~~
Kev Davies
South Wales
Old 17-02-03, 09:24 AM
Funny pass that.... with a fail sheet....
When is the re-test Mr Brown?
Old 17-02-03, 10:44 PM
hi guyes and vince, the work is done for a retest and took all off two hours so hopefully back soon. by the way vince i said i went through the test i never said i past it and my fail sheet was not like a novel hope to see you soon
mark (fat boy northen) }( }(
Mark\'s gallery
Brake caliper slide malcolmbuck Pilgrim Sumo Technical Questions 9 23-01-07 08:03 AM
What size are your male fittings ? cliffords General Tech Tips & Questions 14 13-10-06 07:11 AM
Jaguar brake caliper spacer Speedy Gonzales General Tech Tips & Questions 0 10-10-06 10:26 AM
Flexi Brake hoses for Jag Caliper - Help garyholden General Tech Tips & Questions 8 26-05-05 11:16 PM
Brake fittings Pat General Tech Tips & Questions 5 08-07-04 06:46 PM
