Old 25-02-03, 02:24 PM
starter motor
can anyone recommend above, need one urgently so hoping to get one locally price,make or part no. would be exellent, (5.7 chevy)
thanks
Lardy
Old 25-02-03, 02:25 PM
robert's Avatar
Administrator
RE: starter motor
I might be able to locate a Ford you could use as a starter motor. {-} {-} {-} {-} {-}
&V &V &V &V &V &V
Best Regards
Robert
Old 25-02-03, 02:36 PM
RE: starter motor
now,now. Also the starter motor is only about 10mm from exhaust, does this create a heat problem, is a shield an idea?
Old 25-02-03, 04:51 PM
RE: starter motor
Hi, Try Real Steel (good on price) as there are several starter motors ie depending on Flywheel size, and bolt hole patterns and make sure installer measures the flywheel to pinion clearance and shim as necessary. As regards to heat I have heard it can be a problem although not from experience. Wrapping the manifolds in that area could well reduce heat to quite an extent, what about heat reflective tape on the starter body as well.
Graham
Graham (SRV
Herts
Old 25-02-03, 05:38 PM
RE: starter motor
Heat from the headers can be a real problem causing poor cranking speeds when hot - very embarrassing when you've just filled up with petrol and everyone else is laughing at you bump starting your Cobra!
Suggest you look at the other posts on the forum (use search 'starter motors') - general view seems to be to go for the more expensive but more reliable mini high torque starter as in the Real Steel catalogue.
HTH
Old Starter Motor martin_t Engine Tech Tips & Questions 1 20-08-07 10:51 PM
Starter Motor martin_t Gardner Douglas Technical Questions 1 14-08-07 08:20 AM
starter motor v8 sam DAX Technical Questions 2 15-11-06 03:58 PM
starter motor? jamesandlouisa Engine Tech Tips & Questions 12 27-09-05 06:58 PM
MCI Starter Motor Miket General Tech Tips & Questions 16 06-06-02 11:34 PM
