Old 12-04-03, 07:08 PM
Sealing fuel sender in tank on GD
I have just completed a GD and have noticed a fuel smell when opening boot. It seem that the fuel sender which is mounted on top of the stainless tank and fixed with 6 self tappers is leaking - not around the gasket but around the screw heads - I had put blue hylomar around the screws but this no longer adheres to the sender base.
Any ideas?
Stu Kaynes
Old 12-04-03, 07:20 PM
robert's Avatar
Administrator
RE: Sealing fuel sender in tank on GD
Silicone on the threads and on the hole where the screws go in.
HTH
Best Regards
Robert
Old 12-04-03, 07:47 PM
Hmmmmm...... you need to be very careful if you are using silicon or a silicon based product near petrol, as it has a very nasty habit of reaching with it and if that happens you will have to flush out the whole system. x( x( x(
Martin
Old 12-04-03, 08:08 PM
robert's Avatar
Administrator
Yeah, forgot to mention that..............
Best Regards
Robert
Old 12-04-03, 08:18 PM
Just noticed what that spell check has done to my post it was meant to say reacting not reaching ??
Martin x( x( x( ¦-0
Old 12-04-03, 09:02 PM
I originally used silicone sealant and it did disolve in time , I flushed the tank to remove all traces - so then I tried the hylomar.
Stu Kaynes
Old 13-04-03, 02:46 AM
I had this and it was because my brother-in law who had fitted the sender (his only job!) had bent the apperture for the sender while fitting the sender. After a bit of levelling and proper use of blue silicone no more leaks.
Although this is now fixed, the guage only ever shows half full as a maximum. Anyone have similar problems?
Andy
Old 13-04-03, 01:22 PM
I would not use silicon anywhere near the fuel tank uless you want goo blocking your filters. Like others, a good smear of hylomar or red hermetite on the gaslet faces and under the screw heads works well. Must admit I did not use self tappers but tapped the tank and used short allen bolts because they have flat biggish heads. Also bear in mind some of the smell may emanate from the area of the fuel filler hose or even the fuel pump and hoses if you have 'gone electric'.
Old 29-04-03, 09:37 AM
maxGD059's Avatar
Yup, been there Andy. The cause was a porous float on the sender, making it too heavy to float right up to the top of the tank. it took me ages to sus it out so I hope this helps
Richard
(It'll only be a 5 minute job)
Old 29-04-03, 10:28 AM
So how did you solve it Richard ????
Steve
If at first you don't succeed, get a bigger hammer
Fuel tank sender/fuel gauge Dek General Cobra Discussion 3 16-05-07 10:34 AM
Dax fuel tank sender craggle DAX Technical Questions 4 22-12-04 07:26 AM
Fuel Tank Sender Phil McCann Pilgrim Sumo Technical Questions 2 08-04-04 10:40 PM
Sealing GD Fuel tank sender Stu Kaynes General Tech Tips & Questions 7 06-12-03 05:55 PM
Fuel tank sender David Horsnell Pilgrim Sumo Technical Questions 3 07-04-03 11:47 PM
