Old 17-04-03, 03:10 PM
ian ian is offline
Brake servo vacuum take-off thing broken
On my small block Chevy inlet manifold is a screw-in vacuum take-off bolt thing which should have a small section of pipe coming off it to fix the rubber servo vacuum tube onto. This has snapped off. Can't find a replacement anywhere, even tried Real Steel without success. Does anyone out there have a spare one on an old manifold or any idea where I can get one from? The original came from a std. Chevy manifold, fitted my Holley Contender manifold fine but is missing the top bit as I said. Thanks for any help on this one. Ian.
Old 17-04-03, 04:19 PM
RE: Brake servo vacuum take-off thing broken
RS components do these under air line fittings and are available in stainless(but you need to find someone with a catalogue)
Paul
Old 17-04-03, 04:53 PM
kdavies3's Avatar
From memory I'm sure mine was a brass carb fuel fitting which has the same thread, and I'm sure it came from Real Steel.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 17-04-03, 05:41 PM
RS have an on-line catalogue if you need one.
http://www.rs-components.com/
Tony B
Retired for now......
Old 22-04-03, 10:35 AM
ian ian is offline
Thanks guys. Ian.
Old 25-04-03, 08:49 PM
Can you not attach it to the inlet on the base plate of the carb (Holley?)
Graham
Graham (SRV
Herts
Vacuum brake bleeder Robin427 The Loan Forum 0 26-02-07 05:00 PM
Air Compressor driven (Vacuum) Brake Bleeder Noel General Tech Tips & Questions 8 13-09-06 06:32 PM
Brake Servo glencoe Pilgrim Sumo Technical Questions 6 28-01-05 04:33 PM
Brake Vacuum Pipe Frosty General Tech Tips & Questions 5 25-01-03 10:51 PM
Anyone not using a brake servo? JimT General Cobra Discussion 0 26-05-02 02:25 PM
