Old 11-05-03, 11:51 PM
steering
I am roughly setting up the front suspension and am aware from a previous posting of the figures. But apart from wider front tyres what angle would cause the steering NOT to self centre. (sva req.)? ie caster, camber, toe in/out.
Also do I need nut covers on all the various nut heads etc on th UNDERside of the chassis floor??
Graham
Graham (SRV
Herts
Old 12-05-03, 01:52 PM
RE: steering
Graham,
Caster and no (although you'll rip your arms to shreds every time you reach under if you don't chamfer the edges )
Jim
Old 12-05-03, 08:38 PM
kdavies3's Avatar
RE: steering
hi Graham, some folks have had to unset their camber to get the tyre inside the wheel arch on recent SVA's also had to add toe in for the same reason.
Set it up properly post test.
Kev Davies
South Wales
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 12-05-03, 11:58 PM
RE: steering
Right, cheers. I need to set it up pre test for it to pass though. I have added the now famous wheel arch extensions so I have room to play around . Now where are those settings.....
GM
Graham (SRV
Herts
Steering UVs T-Bone General Tech Tips & Questions 11 14-10-07 06:46 PM
Steering BenBaron DAX Technical Questions 19 28-09-07 10:38 PM
steering Bernie Pilgrim Sumo Technical Questions 17 08-07-07 12:08 PM
Steering Steen DAX Technical Questions 3 16-04-04 07:59 PM
Steering Steen DAX Technical Questions 1 24-02-04 01:28 PM
