Old 12-05-03, 07:02 PM
SBC Casting number - what emissions test will apply?
A novice question....
I have an SB Chevy casting number 3970010 350ci which is shown as 1968-1979 in the David Vizzard book. But because the block has been decked, the engine code number has been removed.
What emissions test will be applied and what proof of age will be required by the inspectors?
Old 12-05-03, 08:30 PM
kdavies3's Avatar
RE: SBC Casting number - what emissions test will apply?
Hi Phil, welcome to the forum.
the casting no. is what you need for the age to be recognised and you have that already.
You will need an engine no. for the SVA and V5 registration etc.
:tu
By the way if that date is correct you will be on 4% co or possibly even just visible smoke it seems to depend on the tester.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 12-05-03, 09:11 PM
dave's Avatar
TO YOU, TO ME
Kev/Phil.
You will only need the casting no. for the SVA as they only need to varify the age of the engine for emission purposes, you may need to take some documentory evidence of the engines age but the VI in Swansea are more than happy with a printout from http://www.mortec.com
If the guys at the SVA test centre are not happy with this info then tell them to call Head Office in Swansea and they will put them right.
When it comes to registration you will need an engine no. , if your engine doesn't have one then make one up and stamp it on, sorted.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 12-05-03, 09:43 PM
Do the inspectors date the engine based solely on the block? I have newer cyliner heads (centre bolt) which may cause a problem.
Old 12-05-03, 10:02 PM
dave's Avatar
TO YOU, TO ME
Hi Brian.
The block is all they are interested in, the heads don't come into it.
:tu
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 12-05-03, 10:06 PM
Phew - That has really put my mind at rest. Thanks Dave :7
Old 12-05-03, 11:52 PM
Right, I have a 3970010 which is as you say, 1968-1979. However the SAME block was also used on the 327, 1968-69 (which is what I will be passing mine off as) though I will utilise the engine id no. (front plate) to back this up. So mine will be a 327 block from 1968-69 but with a displacement of 350 as I have crank rods pistons to make it 350. With me? I will let you know whether this passes next week. If I can provide reasonable proof in support and the tester cannot provide evidence against then there is no question.
BYe
Graham
Graham (SRV
Herts
Chevy V8 Engine casting number bogster General Tech Tips & Questions 4 19-09-06 10:39 AM
head casting number maze Splitpin General Tech Tips & Questions 9 11-09-04 06:15 PM
Exhaust emissions for mot test roger DAX Technical Questions 2 03-08-03 04:33 PM
Showoffs only need apply. Steve H General Cobra Discussion 12 22-07-03 11:05 PM
