Old 12-05-03, 09:34 PM
Cobra289's Avatar
Servo/master cylinder combination
According to DAX the servo/master cylinder combination should be from a Ford Escort Mk5.
My question is:
Does some one know the size of the master cylinder? 13/16 or 1?
Is the size of 13/16? enough to move the Jaguar pistons and maintain short pedal movement?
Nobody can change your opinion!
If I can bring you to doubt, possible you will change your opinion.
http://www.donostia.demon.nl
Cobra289 Gallery
Old 13-05-03, 11:09 AM
RE: Servo/master cylinder combination
I dont know the size but it does work fine. I got mine from a scrap yard and serviced it, I found that all the mk 4 escorts had the same servos in them, just some had a different restrictor in line with them, this isnt used anyhow.
Phil
5.0L TVR EFI Power
Old 13-05-03, 07:56 PM
dave's Avatar
Daddy...I wanna grow!
Ditto to what Phil says.
The brakes may feel spongey for a while, but once they have bedded in they will be "Pin Sharp".
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 13-05-03, 10:07 PM
Cobra289's Avatar
Hi Guy?s,
The problem is I don?t have an Excort servo/master cylinder combination.
I got a Honda master cylinder with a Honda 8? servo. The Honda master cylinder is 13/16? diameter and I will compare with the Escort Mk5 or Mk4 size.
Cam some one check please the size of the master cylinder?
I plan to change the setup for a Land Rover S3 master cylinder and the corresponding 8? servo. So I need some information about the size to make a decision. (Any advise, comments?)
I need to use the 8? servo because the steering column is to close to the servo and it is not so much space left.
I got a LHD DAX cobra.
Regards,
Carlos
Cobra289 Gallery
Cobra289's Avatar
Hi Guy?s,
Regards,
Carlos
Cobra289 Gallery
Brake servo and master cylinder Impulsebooks DAX Technical Questions 0 21-09-07 08:30 PM
Ford master cylinder and servo demus DAX Technical Questions 8 07-12-06 12:09 PM
Which Servo & Master Cylinder?? Martyn-ak427 AK Technical Questions 6 24-09-06 08:33 AM
dax brake servo/master cylinder oiler0 DAX Technical Questions 6 10-01-06 06:57 AM
Which Servo and Master Cylinder cobra.mad General Tech Tips & Questions 3 18-09-03 07:36 PM
