Old 19-06-03, 10:37 PM
rover sd1
if i put a p6 water pump on what pulley do i need ,the one that is on the crankshaft,the one thats is on there don't seem to line up with the belt,
Old 20-06-03, 07:54 AM
russell_ram's Avatar
Club Treasurer
RE: rover sd1
Martin,
you can use a P6 pump, but as you say, the pulleys from a Sd1 won't line up with it. The SD1 has a number of steel pulleys that bolt onto the TV damper assy - which ones depends on whether it had aircon, PAS etc etc - there are many different arrangements. On the P6, the water pump pulley (a big 'flat' one), lines up with a 'pulley' groove machined into the TV damper hub itself. You will either need to have a one-off pulley made for the pump to make it line up with the SD1 crank pulley or have the TV damper machined with a pulley groove to line up with the P6 pulley (or find a P6 damper). see pics
Russ
BTW DJ Ellis does a nice billet aluminium pulley for P6 pumps.
And - you'll have exactly the same problem with the alternator - brackets are different to match the alternator pulley position to the crank/water pump.
The rover v8 EFI Stu J General Tech Tips & Questions 2 18-07-07 07:27 AM
Rover v8 keane General Tech Tips & Questions 0 29-09-06 05:56 PM
Rover V8 mouldb General Cobra Discussion 5 10-01-05 08:21 PM
Rover/Freight Rover V8 Gearboxes Marty V6 Engine Tech Tips & Questions 5 01-11-04 06:41 PM
ROVER 4.6 HELP STEVE G General Tech Tips & Questions 10 28-03-02 08:54 AM
