Old 01-07-03, 05:28 PM
V8bassman's Avatar
Clutch slave cylinder for a Dax?
Help! Can anyone tell me what clutch slave cylinder I should use on my Dax? The engine is a Chevy 350 with a GM T5 (ex Camaro) gearbox. At present, there is absolutely no provision for mounting anything onto, just the actuating arm protruding from the bellhousing. I phoned Dax who were actually quite helpful and suggested I contact Repower, which I did, only to be told by them that their kit doesnt work that well!
I assume that I will have to fabricate some form of bracket to be attached via the bellhousing/engine bolts with holes for a suitable slave cylinder to mount to. Question is which slave cylinder?
Dave
Dave
First Cobra - Dax (sold 2006)
Current Cobra - Hawk 289 (under construction)
Old 01-07-03, 06:20 PM
dave's Avatar
TO YOU, TO ME
RE: Clutch slave cylinder for a Dax?
Hi Dave.
I've built shed loads of Daxes with T5 Camaro boxes, give me a call and i'll tell you what to do.
See Ya'
:tu
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
dave's Avatar
TO YOU, TO ME
Hi Dave.
See Ya'
:tu
Pro Dax Builder
Current builds:-
DB REPLICAS
dave's Avatar
TO YOU, TO ME
Hi Dave.
See Ya'
:tu
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 01-07-03, 06:23 PM
dave's Avatar
TO YOU, TO ME
Oops, i must clean that jam out of my keyboard.
P.S. my no. is 07785 702005
x(
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 01-07-03, 11:28 PM
V8bassman's Avatar
Thanks for that Dave. Will call you sometime Wednesday.
Dave
Dave
Old 02-07-03, 02:01 AM
Yeah I made a bracket that fits to the side of the engine block to rear. Two large bolt holes are on my block into which a 7/8ths rover slave was installed and home made push rod, with 7/8ths master it all works with great travel and medium pressure.All assuming you have straight bell housing. Dave I am sure has an even better solution.
Graham
Graham (SRV
Herts
Old 18-11-04, 07:32 AM
bert's Avatar
Re: Clutch slave cylinder for a Dax?
Dave,
I have the same issue. Is it possible to share your expertise with us by some photo's and a description?
Bert
Netherlands
Old 19-11-04, 10:07 PM
Cobra289's Avatar
Ok let see if I can help you.
I know that Dave will give you a good help like he did with me.
This is an option that I did and will fit in a DAX with Chevy and T5 and the corresponding bell house.
In particular the fork ratio will determine a lot of the setup.
I did have a Hydraulic T/O cylinder from McLeod but I decided to change for an external slave cylinder.
My start point was the amount of kilograms that I want to put with my leg. In my case was 21 Kg.
I made a excel spread sheet to check the forces at the different points.
Normally the clutch force is 180 Kg.
See spread sheet to view the relations and don’t forget that your setup can be different, like the pedal ratio or others.
My result is a Master cylinder of 5/8” and a slave cylinder of 7/8” I use a pull cylinder from Wilwood.
I made a bracket (After several mistakes) and this bracket is fixed to the gearbox holes in that area.
See drawing, the bracket is stress calculated and it pass. (Skorpion has help me with that)
The fork of this T5 is special, because the distance between the pivot point and the push fingers is longer than normal; these is and advance when we are talking about stroke, that means that we need less amount of stroke.
I have also a video how it functions of 8 Mb if you want it let me know I will send it via e-mail.
I hope that this help you or at least show you one of the possibilities.
Regards,
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
"Improvement" means that you recognize previous mistakes!
Old 19-11-04, 10:09 PM
Cobra289's Avatar
More files
Cobra289 Gallery
AK 427 Clutch Slave Cylinder Shakey AK Technical Questions 5 16-03-07 12:16 AM
Clutch Slave Cylinder - Help Viper Viper Tech Forum 6 06-02-06 07:02 PM
Clutch slave cylinder Elmo General Cobra Discussion 1 15-03-05 04:34 PM
Clutch slave cylinder simon General Tech Tips & Questions 15 27-01-03 03:57 PM
Clutch slave cylinder simon General Tech Tips & Questions 4 24-02-02 02:21 PM
