Old 17-08-03, 02:13 PM
compression ratio
What is the safe maximum compression ratio for my Ford 302, using the current fuel available?.
I'm using a mild 268 degree cam with +40 pistons and I intend to change to alloy heads.
Thanks Steve
Old 19-08-03, 12:41 PM
JamesP's Avatar
RE: compression ratio
Given a few discussions on this forum re compression ratios I believe the consensus is that if you go over 9.5CR you'll need to run on Super Unleaded, the Ally heads complicate the matter as many experts believe that you can run between 0.5 - 1 CR higher on same fuel before detonation as the heads run cooler. The shorter cam also will increase the 'Dynamic' compression ratio as the intake valve closes earlier.
Have a look at the attached excel file, I built this to give me an idea of what comperssion ratio I'd be getting and by putting in your cam specs it'll give you an idea of the dynamic compression to be expected as well. Reference points given are for a small block chevy as per David Vizard books but should be similar for your engine.
For reference I'm building a 383 SBC with AFR Ally heads with about a 10.2CR, I'm going to use the Edelbrock ProFlo RPM Multipoint Fuel Injection which may also help in reducing detonation due to better atomisation of the fuel in comparison to a carb.
My hope is to run on Standard unleaded but will go up to Super if get detonation or the performance is significantly better.
Hope this helps
James
'Every journey begins with one small step'
Megasquirted 383 SBC built but yet to start.
Dax De Dion chassis safelty in garage.
Permission to spend money in March - rolling chassis here we come
Old 20-08-03, 10:36 AM
thank you James, just what i was looking for.
steve.
compression ratio Splitpin General Tech Tips & Questions 1 28-11-04 11:57 AM
Compression? what compression?! the results of the smash com smash General Tech Tips & Questions 7 10-09-04 01:17 PM
Help required with compression ratio... Andy302 General Tech Tips & Questions 23 22-08-04 09:50 PM
Compression ratio with this combo? Andy302 General Tech Tips & Questions 3 15-08-04 08:09 AM
Compression Ratio. Andy302 General Tech Tips & Questions 4 15-01-04 05:29 PM
