Old 15-09-03, 10:28 PM
Hot Starting
Hi,
First time on the forum and I was wondering if any one out there could help me?,realised a dream and bought my Dax cobra at Stoneleigh this year and have a had an excellent summer scaring myself discovering how many great roads there are in the north east of England. Unfortuantly I`ve also discovered something called "hot starting " or at least thats what I`ve been told is wrong with the car. After every drive once I`ve turned of the engine(ford 302) it seem that I have to sit for what seems like an eternity before I can star the car again (very embarising at my local garage!).
Does any one have any advice on how I can get over this problem?
Thanks,
Tim
Old 15-09-03, 10:35 PM
RE: Hot Starting
Do a search on the forum, this has been covered plenty of times.
One solution is a remote starter solenoid, but I can't really see how this works.
Best solution may be to obtain a gear reduction starter (also called mini high-torque starter). I use one on the GD and even with a little 36Ah battery (Standard fit on a 1.3 Astra!) it throws the 350 Chevy over as if it was a motorcycle engine!
Simon.
Old 15-09-03, 11:59 PM
RE: Hot Starting
I have recently fitted a remote st. solenoid (350SBC) after experiencing this very problem and it has solved the problem. There are two methods of wiring this I have them printed out. The solenoid is a Durite item from Staff vehicle components with push button as well. Honest this method has most certainly cured all my hot start problems.
I did not go for mini hi torque starter as I have heard the heat soak can affect these though not as much, also I would have thought that you would have to reshim the new starter and to do this accurately surely engine has to come out to see the mashing of pinion and flywheel properly???
Graham
Graham (SRV
Herts
Old 16-09-03, 09:45 AM
maxGD059's Avatar
RE: Hot Starting
Tim
I assume that you try to 'hot start' the engine with 50% throttle, having not pumped the pedal first? My RV8 can be a pain to 'hot start' unless I do this, & then I have no problem at all -just a thought
Richard
(Hillclimb convert)
Old 16-09-03, 01:26 PM
RE: Hot Starting
I used to have this trouble about 4 years ago, with my Holly and RV8.
I removed the automatic choke spring, starts first time now , even in the winter. Also another member had this starting trouble it was the condenser. The last thing you think of.
Graham
Old 16-09-03, 02:16 PM
RE: Hot Starting
The remote solenoid does work, it dosent matter whether you understand it or not just think £7.50 vs £150 +. The latter is for a mini torque.
I have posted an explanation and diagrams of how it works about a month ago.
Best of luck
Mike
Old 20-09-03, 12:25 AM
RE: Hot Starting
2nd that, Well chuffed with mine. Didn't think the original problem could be so bad.
gRAHAM
Graham (SRV
Herts
Old 09-10-03, 08:00 PM
RE: Hot Starting
Thanks all for the advice,I`v been away so its the first time I have had time to respond. I did the search on the forum and came up with what had previously been suggested by others with the same problem.
Having checked what I have already got I find I have a remote solenoid fitted to the car, its not far from the exhaust manifold, should I move it? would that make a difference to problem?
Tim
Old 10-10-03, 09:22 AM
RE: Hot Starting
Yes
The idea is that you keep the solenoid cool. For the price of the solenoid, use a new one when you reposition away from headers etc.
Use the wiring diagram I previously posted.
Hope it works for you.
Mike
hot starting - perky Engine Tech Tips & Questions 20 24-01-06 09:01 AM
Just starting out??? GUMBALL General Cobra Discussion 0 24-09-05 10:20 AM
Just starting an AK Brian T General Tech Tips & Questions 5 17-09-04 01:13 PM
just starting acspeeder Newbies 3 30-08-04 08:06 PM
hot starting Clarkson General Tech Tips & Questions 16 12-08-03 09:50 PM
