| RE: After Market Valve covers Hi James. 2 holes, one in each. PCV c/w breather & baffle (all in one unit on one side. The other side should be connected to the PCV port on your carb. Rgds. Rob:tu
__________________ Cobra-less |
| RE: After Market Valve covers Ooooops, forgot to mention that the valve sits in a rubber grommet in the hole. The crankcase is ventilated by the 'vacuum' in the carb pulling gasses from the crankcase to be burned off with the air/fuel mixture. 'Fresh' air is then 'pulled in' through the PCV valve. The baffle inside the valve is to prevent oil from escaping from the rocker cover. Rgds, Rob
| RE: After Market Valve covers James You are better to use a PCV valve on each rocker cover. I side to PCV inlet on carb and the other PCV valve to outlet on underside of air filter.
| RE: After Market Valve covers Rob Many thanks for clearing that up, always wondered what the breather was for if you had a PCV valve. I thought that the engine was effectively held under a vacumn through the connection to the carb. So I need to find a breather that I can fit to one cover and a PCV valve on the other connected to the throttle body plus some grommets and a filler tube unless one of these can double up. Many thanks James 'Every journey begins with one small step'
__________________ Megasquirted 383 SBC built but yet to start. Dax De Dion chassis safelty in garage. Permission to spend money in March - rolling chassis here we come |
| RE: After Market Valve covers All the bits you need are in the Summitt catalogue. I'm surprised they sell covers without provision for breathers and PCVs though. Are they for strange race engines or something. http://animatedgif.net/flags/-flags-uncat/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: After Market Valve covers I'm building an order for Jegs at the moment and these will be the last bits I need before the intake/efi/dist/Accel DFI system which I'll order in the new year (need to save up as near £2000). The covers I saw were cast ali items with an angled top so that the breathers are level, with 'Chevrolet' embossed across the top. Think there Nascar racing items. They included a boss so that you could drill your own holes. They don't list them in Jegs/Summit with breather holes but you can get them. Have since spotted the price $350 so think I'll be going with some polished ali items at $100 including 1.22" holes & baffles, the PCV & breather are still separate though. Still tempted to go for some AFR covers to go with the heads, polished ali with 'AFR' in bold across the top, $42 each +shipping/duty etc, but that may be showing off too much for my liking. James 'Every journey begins with one small step'
| RE: After Market Valve covers If you are fitting a Chevy engine, I have a pair of very nice 'Cobra Le Mans' covers for sale at £50 Rob
| RE: After Market Valve covers Rob, check your e-mail please. cheers http://animatedgif.net/flags/-flags-uncat/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: After Market Valve covers Rob Now those I like, where did you get them from and do they do them unpainted? James 'Every journey begins with one small step'
| Cobra Valve Covers | Carl L | AK Technical Questions | 9 | 31-12-07 06:25 PM |
| Leaky Valve Covers | Warren | Engine Tech Tips & Questions | 1 | 16-09-07 09:21 PM |
| Valve covers for SBC | Spanish Dave | Engine Tech Tips & Questions | 2 | 06-09-07 09:07 PM |
| Chevy Valve Covers | rudy | Pilgrim Sumo Technical Questions | 7 | 22-11-05 10:54 PM |
| Edelbrock valve covers | Splitpin | General Tech Tips & Questions | 2 | 04-03-05 10:01 AM |
