| Tonneau cover fixings Hello Guy's, Before the body goes into the paint shop, i was hoping to fix tonneau cover fixings!!...does anyone have a sketch showing positions..etc.....shall have to have a 'purpose' made tonneau i suppose?.....(Body is a RAM..with twin roll hoops) Cheers dave |
| RE: Tonneau cover fixings You will almost certainly need a custom made job to fit the shape of your cockpit and the location of the rollover hoops. A good trimmer would be able to produce the tonneau cover and fit the fastners for you to ensure a smooth tight fit. I had mine made earlier this year for £260 which, for a piece of plastic sheet (vinyl) seemed expensive until you consider the time taken and the specialised knowledge. |
| RE: Tonneau cover fixings Contrary Mary Dave this may help you, Tonneau Cover made for me buy MD Mand in Linc's. Made a paper template for them to work off, then they made it up in heavy cardinal black (Double Duck)to match the hood which fits on the same studs not the easiest of shapes either Eric. |
| RE: Tonneau cover fixings Contrary Mary Normal fixings Charlie, Tenex & Lift Dots, most Cobras are done that way. There was a post a while ago re GD I think with there new type hood/hard top, but as I understood it you had to have a permanent fixing on the rear. Perhaps some one else could give you more detail on that score. I have a few more studs than most, but that's why I can use it in the rain and wet @100+ with no ill effects except for my undies! The hood is 93% water-tight, also both units fit well, no sag unlike the rest of my body. You will notice the side screens are the zip type so extra studs required Eric:tu |
| RE: Tonneau cover fixings Contrary Mary Paul you are such a PR~TT!!!!!{-} I got a upper flux capacitor with colour dust added complete with BY127 diode together with a PL 380 valve too stop the frame roll, converted it to water readings & stuck it up my rear end, and that came out was only 7% of the total input, does this answer your question!!?? Little wonder people say to me who is that wan#er Dutch Paul!? Does he live up north? Who knows I reply Eric |
| RE: Tonneau cover fixings Eric, I think you are being very harsh on your self I'm sure not all of you is sagging{-} {-} {-} {-} {-} Martin :tu :tu :tu :tu
| RE: Tonneau cover fixings :7 :7 :7 :7 :7 :7 PS. Thanks for the compliments Eric{-}
| RE: Tonneau cover fixings That should cure halitosis Mike Ahhh...I see the screw-up fairy has visited us again... |
| Tonneau Cover | taurus | General Cobra Discussion | 3 | 06-07-06 02:32 PM |
| Tonneau cover for Sumo | jools | General Tech Tips & Questions | 4 | 16-04-06 04:24 PM |
| tonneau cover fitting help please !! | monster.chub | General Cobra Discussion | 16 | 06-04-06 11:56 AM |
| Viper Tonneau Cover | monster.chub | General Cobra Discussion | 7 | 20-02-06 12:07 AM |
| Tonneau cover | mikeb | DAX Technical Questions | 6 | 08-02-05 08:31 AM |
