Old 27-10-03, 12:12 PM
Red Top Battery Terminals.....
Hi All,
just got hold of a red top 40 battery and have discovered that it has little tiny terminals, not the standard battery terminals.
I have the battery cables from Dax which have big beefy ends on them...what do I do?
cheers
Ben :}
kreativejuice...
www.kreativejuice.co.uk
Old 27-10-03, 12:28 PM
robert's Avatar
Administrator
RE: Red Top Battery Terminals.....
Cut them off and resolder some lugs from the nearest auto factors.
Best Regards
Robert
Old 27-10-03, 01:15 PM
hi Rob,
you on about cutting the battery or the cables?
cheers
Ben
kreativejuice...
Old 27-10-03, 01:26 PM
robert's Avatar
Administrator
Unsolder the existing terminals from the cable and resolder or clamp some new ones on.
HTH
Best Regards
Robert
Old 27-10-03, 02:38 PM
cheers Rob,
sounds easy enough, do you happen to know which type of terminals I need?
cheers
Ben
kreativejuice...
Old 27-10-03, 02:45 PM
robert's Avatar
Administrator
Sorry, it was some time ago and I can't remember
Best Regards
Robert
Old 27-10-03, 02:55 PM
no worries,
cheers anyway...
kreativejuice...
Old 27-10-03, 07:56 PM
The battery has an M6 connection.
The terminals you need are high current ring crimp terminals.
You also need to know the size of your battery cables in mm2, I'm not familiar with the Dax, but the GD uses 25mm2 cables as the battery is in the front.
If your battery cables were 25mm2 the marking on the crimp connector would be something like "CT25-6", the letters may change depending on manufacturer of the crimp. Similarly 35mm2 cables would need a "CT35-6" crimp.
Never use the incorrect size of crimp, as the connection will be substandard and a fire risk with the current flow required for a starter motor.
If you can take the battery cables to an industrial electrician (or an auto electrician who does larger jobs), they will have the correct ratchet or hydraulic crimping tool (with hexagon dies) required to correctly apply the crimp to the cable. Manual indent types aren't that good, and require a lot of force to operate.
Failing that, you can always solder the terminals on to the cables, but the connection resistance will be slightly higher (though it shouldn't be a problem)
Simon.
Old 28-10-03, 03:25 PM
cheers Simon,
much appriciate the info...
Ben
kreativejuice...
Old 28-10-03, 05:03 PM
Ben,
Dave Brooks has the right crimping tool,I know this because i got it for him.Did my Dax cut off switch with it.
andy.m.
Battery Terminals? - Soldered or Screwed? cobrasrgrate General Cobra Discussion 9 20-03-07 02:25 PM
ht lead terminals craigh General Tech Tips & Questions 3 04-03-07 06:26 PM
Tremec TR500 Gear Box Reverse Terminals Colin Peet General Tech Tips & Questions 1 10-06-06 11:11 AM
which battery milner Engine Tech Tips & Questions 1 15-03-04 05:27 PM
Battery Terminals CT50-6 .... BenBaron General Cobra Discussion 0 31-10-03 09:42 AM
