Old 28-10-03, 06:47 PM
STEVE G's Avatar
Inner wishbone mount??????
As I,ve posted elsewhere I'm just starting to recon my back axle.
On removing the wishbone I found the pivot brkts both loose.They are both wired so the bolts could'nt come any looser but it did'nt seem right.When I checked the "new" Dif I found the same thing.This dif has just come out of an '87 jag(worked out from the date stamp inside the dif cover).
Has anyone else noticed this and cured it.The manual says 60lb torque plus wires so I would'nt have thought the bolts would come loose,but seems a coincidence on 2 difs.
I think I'll wack a load of thread lock in to be safe.
Steve G {-}
GE427-Rover 281ci.(300+BHP)
Regards Steve G
Old 28-10-03, 08:18 PM
RE: Inner wishbone mount??????
My father has worked on Jaguars for more than 30 years. He told me that it is a common problem and wiring is not the cure, it will just prevent it from falling apart. He used Loctite when we assembled my back axel. It’s not bullet proof but better than wires alone.
/ Bowtie
When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there\'s no end to what you can\'t do!
Old 28-10-03, 09:04 PM
same here loose bolts,even the shims had fallen out loctite was used on re assembly
gd jag,ford 302,tremec tr3550
Old 28-10-03, 09:30 PM
My father avoids the shims since they usually just increase the chance that things come loose.
Old 29-10-03, 10:39 AM
STEVE G's Avatar
Thanks Lads I recieved the same advice from Classic spares in waltham cross.Just glad my axle wasnt the only one relying on 2 pieces of 20swg wire.
Steve G {-}
Regards Steve G
Inertia mount Stu J Pilgrim Sumo Technical Questions 4 02-09-07 12:52 PM
Where to mount speakers? V8 BJC DAX Technical Questions 13 20-02-05 09:55 PM
Ram bottom Jaguar wishbone shock mount? Antony General Cobra Discussion 13 13-02-05 01:20 PM
gearbox mount craigh Engine Tech Tips & Questions 1 04-11-03 07:18 PM
AK RV8 Alternator mount kev AK Technical Questions 4 07-12-02 10:36 PM
