Old 10-11-03, 10:48 AM
Coolant Woes
Pilgrim Sumo, 2.8V6 Cologne.
Fired the engine up for the first time yesterday with great success, apart from coolant issues. WHAT A BUZZ!! Prior to the start up I'd got about 8 pints in and there was no drop in the level after about 10 mins of engine running......... result hot engine (i think as I had not temperature gauge on it, only an oil pressure gauge)!
Then we had the bright idea of back-filling from the heater to try and force the air out. Quite a bit of success, we managed to get another 8 pints in.
Started the engine up again, this time all the hoses seem to get warm and engine seemed to stay cooller and then............ after about 5 minutes of running, the pressure must have built up and out p&*sed 3 pints of coolant from the overflow outlet in the expansion tank. Net coolant in the system is about 13 pints. Haynes manual says I should have 16!
Does all this sound OK and I have no problems? Or do I still have an air-lock? If so, how do I get it out??
Thanks
Old 10-11-03, 11:31 AM
Club Sec/Rep Liason
RE: Coolant Woes
Sounds normal for a cologne, Try topping it back up and see what happens? Are you running the viscous fan? If not did the fan cut in?
AK 427 351C T5wc
Old 10-11-03, 11:34 AM
RE: Coolant Woes
Nope. Twin electric fans as per Pilgrim recommendation. Radiator was warm/hot but fans had not kicked in. I lost my bottle at that point as I had no means of knowing the temperature and didn't want to risk anything.
Old 10-11-03, 11:51 AM
kdavies3's Avatar
RE: Coolant Woes
Often bleeding of a new system can be improved with the thermostat removed or jacked open.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 10-11-03, 11:53 AM
Club Sec/Rep Liason
RE: Coolant Woes
Like I said try topping it up and running it again, it's amazing how much trapped air you can get. If it still happens it try shorting the fan switch and see what happens.
AK 427 351C T5wc
Old 10-11-03, 11:54 AM
RE: Coolant Woes
Any other way? I don't want to take the risk and open the system once again by removing the thermostat.
Old 10-11-03, 12:01 PM
kdavies3's Avatar
RE: Coolant Woes
The thermostat is one of ther higher parts of the system so you won't lose much.
Often allowing it to cool and then refilling / topping up can help too. This may need several attempts before all the air is purged.
Kev Davies
South Wales
:tu :tu :tu
Kev Davies
South Wales
air keeps returning in coolant v8 THE ELK Viper Tech Forum 8 29-06-06 05:45 PM
Coolant fiona General Cobra Discussion 1 20-06-06 12:32 PM
Coolant Woes David Parkes Pilgrim Sumo Technical Questions 0 10-11-03 11:00 AM
Getting Coolant into the System David Parkes Pilgrim Sumo Technical Questions 2 05-11-03 10:59 AM
RV8 filling up with coolant Kevin W Pilgrim Sumo Technical Questions 4 30-04-03 01:11 PM
